E to I swap running like poop
  • mpowerful
    • Jul 2013
    • 1273
    Id put the breather hose back on. I mean we are talking about a motor that nearly bogs and dies when you take the oil cap off.
    • AndrewBird
      The Mad Scientist
      • 11898
      Yes, breather hose is a BIG vacuum leak.
      • dougie30
        • Apr 2012
        • 1708
        No this wasnt resolved, well I didnt fix it. The bogging down I believe is a vacuum leake that I cant find for the life of me..
        And the hard bucking did stop. I couldnt find out what the issue with that was either.
        Sent from my SPH-L710 using Tapatalk
        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
        • squidmaster
          • Aug 2011
          • 2666
          Buy cigar, puff on it, blow into intake, find leak.
          scotty kilmer to the rescue!
          (I think everyone's seen this video https://www.youtube.com/watch?v=zMok2y05jNE)
          • Regnar75
            • Sep 2011
            • 483
            ^that works. i would check your valve cover breather hose, and the AFM are big issues. did you go from motronic 1.0 to 1.3? or what?
            • dougie30
              • Apr 2012
              • 1708
              I will probably give that a try this weekend, you just blow smoke into the intake? should the throttle be closed or open?
              and i replaced the valve cover breather hose and what is a good way for checking my afm?
              • squidmaster
                • Aug 2011
                • 2666
                Originally posted by squidmaster
                you need to test the resistance on the AFM, so a normal voltmeter won't work.
                You connect positive to pin 3 and thruput to pin 1 I believe. should go smoothly from 2.2kOhm to 2.7kOhm, as you move the needle from one side to the other, at around 75'F
                Now that's just all from the top of my head, so you can google "test m20 afm" to see what comes up to check my work
                (looking from the top)
                ___________
                | 1 2 3 4 |
                you could actually use a voltmeter, but you'd have to supply voltage to the afm to test it properly.
                  In about than 15 minutes a properly executed smoke test using an oil smoke generator will find the leaks. There is no substitute. Understand that if there is a gross leak(s) that shows up immediately, it will have to repaired and the test repeated. You can only say that there are no leaks when 2-4psi of smoke pressure can be held for over 5 minutes.
                  • dougie30
                    • Apr 2012
                    • 1708
                    Ok so how would I supply voltage while testing the afm? Maybe 9vbattery? And jlevie I dont have access to a real smoke tester uless maybe a local shop would have one around.
                    • Swanny
                      • Mar 2012
                      • 2834
                      Easy DIY with some paint cans, tubing, and a few cheap connectors.
                      Have done this with great success can be made for under $20.
                      Swanny!
                      SUCKERS.
                      • Regnar75
                        • Sep 2011
                        • 483
