A few ideas in my head
  • rcsoundn1
    • Nov 2012
    • 3361
    cold air intake adds at least 10hp man!
    • darvo
      • Dec 2010
      • 407
      Originally posted by dougie30
      Darvo-i really dont know much about ms so i proba ly would need someone to build it and tune it for me
      Sent from my SPH-L710 using Tapatalk 4
      You could always buy a MarkD chipped ecu for your car.
      I would say basic maintenance, schrick 272 or a bimmerheads 274, lightened flywheel on stock clutch, exhaust, chipped ecu for your mods.
      There is no way you can make your car fast with $200 and 2hrs of labor(unless you use a nitrous kit). Just make a list, a monthly budget, buy and pile up parts, and when your all set to go, install.
      • deutschman
        • May 2008
        • 5958
        What this guy said. $200 bucks wont get you much at all. Maybe even make you slower if you get the wrong stuff.
        -I would get:Bimmerheads (Mr. E) head with a 274
        -A ITB set up because one of the single biggest restrictions on an m20 is the OE metal intake.
        -Some 19lb injectors.
        -Some sort of after market tuning system with a real tune.
        Its going to cost good money but if you really want more power you have to make some big changes. Everyone dreams of the Saturday bolt on 100hp upgrade but it really does not work like that.
        • dougie30
          • Apr 2012
          • 1708
          Yes this is pretty mich what i needed to hear. I understand that 200$ and a few hours wond do anything but i was tryong to get some ideas flowing.
          Good idea with the budgeting also i just dont want to dump tons of money into my m20 and not have it be worth it you know?
          I appreciate the ideas guys i really do
          M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
          • digger
            • Nov 2005
            • 6198
            Originally posted by darvo
            Thats not a tune, just how I bought the stock car, Í had the megasquirt before the car was bought so I never gave the motronic a chance.
            What about the last tune on the b25?
            i know it was not tuned but there was something wrong i think, for things to be that far out even with bog stock motronic and chip....
            if you want to compare you need to compare a tuned motronic to tuned MS
            • e30trooper
              • 11576
              lighten your car and it will feel faster. I did the i head conversion. decked head stock eta block , alpina rep chip on stock injectors and eta exhaust system. I felt like it moved well..
              for $600
              this vid was on a stock chip and 87 gas
              • dougie30
                • Apr 2012
                • 1708
                Damn that does seem pretty quick. I think iv done well on lightening my car tho i have no carpet and no sound deadoning bit im for ed to carry a heavy ass jack and a spare incase i get a flat or something.
                • darvo
                  • Dec 2010
                  • 407
                  Yup, I know. That's why I said I didnt give the motronic any chance.
                  I hope the new engine gives pretty good results ;D
                  Thanks for your help Digg..
                  Still waiting to see a vid of your car in action
                  • dougie30
                    • Apr 2012
                    • 1708
                    Also im pretty scared of the custom engine management... like megga squirt.
                    I just dont under stand it. Like would i have to build it and program it? How woukd i go about programing someyhing like this? Im not very comp savy so i try to stick to stock motronic ecus
                      • 34844
                      on a stock motor, ITBs aren't going to do anything for you other than kill the low end and cost a lot of money. the stock intake manifold isn't a restriction on a stock motor.
                      at the end of the day, just get a chip. forget the rest of the mods - if you don't want to learn how to tune it, they're mostly going to be a waste of money. spend the money bringing your M20 up to factory freshness.
                        • 34844
                        I think the idea here is that MS is a lot easier to tune than Motronic is.
                        it also proves that the AFM barely makes any difference on a stock motor. a $300+ MAF conversion is a waste of energy.
                        • digger
                          • Nov 2005
                          • 6198
                          no doubt its easier, but X* of timing is X* of timing, and Y AFR is Y AFR so at WOT not likely to be a huge difference except those due to the different inlet system.
                          When i went from a tuned motronic M30AFM system to standalone a decent bump in midrange torque was found but no real peak hp.
                          even if the AFM isnt really restricting a stock system it is a far superior metering system and driveability gains would probably be worth the effort IMO. ive never used the system you refer to to know if it is a refined setup.
