m20b32 11.0:1 CR cam selection
  • ForcedFirebird
    • Feb 2007
    • 8300
    #31
    The root of a good tuner doesn't change, only the software and hardware does. Understanding engine behavior is a dying art. There was no wide band growing up, no ECU's etc. Best form of mass or long distance communication was tele or letter lol.
    john@m20guru.com
    Links:
    • pantelones
      • May 2011
      • 533
      #32
      Originally posted by digger
      we should start another thread lol
      Yeah... My bad for derailing this one hahaha OP it seems like the 288* cam is a good choice.
      i also wonder about the "newer" injectors and spray patterns and how these compare to the stock ones and if they are any better....
      To my understanding the 4 pintle (or more...) injectors create better fuel atomization; gasoline does not burn in it's liquid state as we all should know, so the more of a vapor state that it can be introduced into the combustion chamber the better. Right?
      Also, the difference between low and high impedance is beneficial to your tuning capabilities... See the link below; questions 3-7 explain this pretty well.
      Fuel Injector Clinic offers high performance fuel injector Data Matching for both High impedance and Low impedance injectors. Dynamic Cleaning and injector flow testing.
      A man chooses, a slave obeys... Would you kindly?
        • 34847
        #33
        low impedance no longer have any real advantages. the newest high-z injectors are as fast as the low-z injectors of yesteryear, and they're less complicated to control. actually that link says that exact same thing so I dunno if you're agreeing or not. lol
        • pantelones
          • May 2011
          • 533
          #34
          LOL Yes that's what I am pointing out... Trying to be objective and use the link to explain as we have seen where my subjectivity leads haha
          • digger
            • Nov 2005
            • 6215
            #35
            http://fuelinjectorclinic.com/faqs/#3
            atomiziation is one thing but whether you spray a narrower pattern directly on the hotter valve or on the colder port walls is a seperate issue. my research says that you dont want to spray too much onto the port walls as it forms rivers of fuel on the runners that doesnt burn well when it gets into the chamber and it is a safe bet the spary onto the valve. but what is too wide and what is too narrow?
            • ForcedFirebird
              • Feb 2007
              • 8300
              #36
              As close as the injectors are in an m20, doubt the spray would hit the port walls. Be interesting to mock up a real world scenario just to see.
              john@m20guru.com
              Links:
              • digger
                • Nov 2005
                • 6215
                #37
                off top of my head the injector is what 3 to 4" away from the valve? the port is about D38mm(1.5") in that area 2 x invtan 0.75/4 = 22-28* so anything wider than 22-28 degrees (included angle ) will start to hit the wall. how much is too much? is an injector designed for 4V engine best for the 2V?
                mainly what im pointing out is how many M20 guys know what the spray pattern of their injectors is and if it is the best one for the job ? ive not really paid attention to it as long as it flows what you want it must be good right?.....fuel preparation is extremely important.
                • doktor_b
                  • Jun 2013
                  • 61
                  #38
                  Originally posted by Doktor_BS
                  I remember when I thought I had a "racecar"...oh and i thought my car was "Low" get real.
                  I'm flattered that you started troll account just to be a dick to me.
                  to everyone else, i went ahead and ordered the 288 so we'll see how it goes.
                  this injector discussion is a ton of good info, albeit a little off track. thanks for all the input!
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #39
                    The pintle caps are almost flush with the manifold when installed. Measuring from the manifold gasket to valve is roughly 2", but yeah, guess the walls may be sprayed slightly. The injectors I used are not a very wide angle, but not the "squirt gun" effect like the ancient m20 injectors.
                    john@m20guru.com
                    Links:
                    • doktor_b
                      • Jun 2013
                      • 61
                      #40
                      so, i'm having trouble posting in e30tech.
                      i've been reading all the threads about head porting/shaping/flow/etc.
                      my question is this, how do i get my head properly sorted? i ordered all the components. +1mm valves, VAC springs & retainers, all new seals guides, etc.
                      but i don't have a flow bench. considering the cam and short block build, just a fresh head will make a boatload of power. but i want to go big while i have the chance. do i just send my head off to someone with all my bits and have the ports refined? or should i just cancel the valves and get a fresh valve job on my stock valves and the 288 and leave the ports alone?
                        • 34847
                        #41
                        you send it to somebody who knows what they are doing
                        if you are going 86mm then the +1 valves should work fine, but your pistons will need to be made so you don't have clearance issues.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #42
                          Best answer! Don't mess with the ports, we ruined some m20 heads in the name of research, and it's very easy to ruin flow.
                          Adding larger valves just to "port" them and ruin flow, might as well leave the stock valves in and save the machining cost.
                          john@m20guru.com
                          Links:
                          • doktor_b
                            • Jun 2013
                            • 61
                            #43
                            pistons are going to be clearanced appropriately. already took care of that.
                            as for the headwork, who do you guys recommend? i'm leery of the local shops "hogging 'em out" and being worse off than i am now. normally, i have two shops i send heads to for this type of work, but what i've been reading leads me to believe that someone with experience with these heads is going to net me much better results...and with much less risk of running my flows afoul.
                            or am i going to be ok just sending it to a local shop that specializes in this kind of work?
                            (i really don't want to f this up.)
                            thanks
                            • doktor_b
                              • Jun 2013
                              • 61
                              #44
                              similarly, what happens if i just install the larger valves and don't touch the ports?
                              • digger
                                • Nov 2005
                                • 6215
                                #45
                                with oversized valves you need a new valvejob, cut throat size appropriately and massage the short side and bowl and blend it and streamline the guide a little better. probably some deshrouding to, most of the casting doesnt need to be touched
