Breaking in new Cam and Rockers in an M20
  • EyExR
    • Jan 2011
    • 959
    Originally posted by nando
    Its where the old mechanical distributor went, drivers side of the engine, just above the pump. A diagram on realoem will help visualize.
    This is what I did and it worked. But I have to say, that dropping the hex shaft into the block is a very easy mistake to make when doing this procedure. I lucked out and managed to drop it right back in place but it was nerve wracking!
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • TobyB
      • 5297
      You don't want to go to 2500rpm until the engine is at normal temperature.
      The cams I have used have said to go to 2500 as soon as possible. So I do.
      I also use either a ZDDP additive or proper break- in oil. I had a cam eat itself
      once, and that was quite enough, thank you! It's too cheap to use to NOT use it.
      t
      • Earendil
        • 1662
        Okay, followup question after reading two different opinions (on non-BMW engines). Do I moly lube ONLY where the camshaft touches the head, or do I lube where it touches the rockers as well?
        1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
        2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
        I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
        • Earendil
          • 1662
          Well. Parts arrived. Camshaft looks like it has defects. Any thoughts?
          • digger
            • Nov 2005
            • 6206
            on rockers and lobes to
