Upgrades that aren't crazy $$$$ ?
  • mitchlikesbikes
    • Dec 2013
    • 858
    weight reduction. you can do a LOT of it for free.
    IG: @mitchlikesbikes
    • TheTacoMan
      • Nov 2011
      • 2308
      Ac/ power steering, trunk tar, windshield washer reservoir, stock seats, rear seats can all be taken out if you are really wanting to weight reduct.
      • Bearmw
        • 1323
        If you haven't done it how about a lighter flywheel and maybe a 3.90 LSD? It wont gain a ton but its cheap. I'm all for lighter wheels as well.
        • redlightpete
          • Mar 2012
          • 265
          Originally posted by Bullet Ride
          Here's some dyno proof that a properly designed set of ITBs on a stock M20 is good for roughly a 25whp increase... http://www.e30tech.com/forum/showpos...42&postcount=1
          Were those itb dyno runs done with stock timing? If not, that might account for a portion of the gains.
          • digger
            • Nov 2005
            • 6196
            it was tuned with a standalone ECU at the same time so some gains would be from the better tune. i can tell you though that you dont get topend peak to peak gains like that with a tune on a stock m20b25.
            • 603Racing
              • Dec 2010
              • 612
              I've done a lot of weight reduction:
              • All "cosmetic" stuff from the trunk is gone
              • Radio and all speakers are removed
              • OBC removed
              • Cruise control equipment removed
              • Put lighter 15" TRM wheels on the car
              • knee bolster gone
              • Fogs delete
              • Lightened flywheel
              • 3.73 LSD
              Kept the sport seats, but they are not that heavy. Dont' want to spend a lot of money on aftermarket seats to save a few pounds. I remove the AC belt at the track. Car is already stripped about as far as I'm willing to go as I driver the car several times a week and like to keep the AC and washer fluid. Suspension is full spec e30 setup except I have adjustable front bar.
              I appreciate all of the ideas and feedback. My next steps are probably m30 AFM and a tune. That will have to be down the road a bit.
              90 325i DD/Track
              03 Durango 5.9
              Originally posted by e30mpg
              It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
              • 603Racing
                • Dec 2010
                • 612
                I'm coming back to this...
                I'm going to bring up the M30 afm topic, for the billionth time. Is this even worth doing? I mention it because I happen to have an 027 afm just sitting in my parts collection. I have type 3 (genIII) 19# injectors I will be installing with my head swap to the previously mentioned head (272 cam and 3 angle valve job).
                Is there a MarkD 93 chip for a 027afm and 173ecu setup? I've read conflicting information on this.
                90 325i DD/Track
                03 Durango 5.9
                • squidmaster
                  • Aug 2011
                  • 2666
                  I've got tunes out the bum for m30 AFM with all sorts of cams. Just saying ;)
                  • Bullet Ride
                    • Dec 2010
                    • 598
                    Any dyno plots to back up the tunes?
                    • squidmaster
                      • Aug 2011
                      • 2666
                      Depends on the tune you're asking about.
                      • Bullet Ride
                        • Dec 2010
                        • 598
                        I'm just curious to see what the gains are in general... care to share a couple?
                        • amcp
                          • 489
                          • OBC removed
                          • knee bolster gone
                          • Fogs delete
                          • 3.73 LSD
                          You didnt do all these things..... :)
                          • 603Racing
                            • Dec 2010
                            • 612
                            Hey, stop thread bombing me! :)
                            On topic... Squid does have some good information. I'll let him share if he desires.
                            90 325i DD/Track
                            03 Durango 5.9
                            • squidmaster
                              • Aug 2011
                              • 2666
                              I'll be posting more when I get back in the office! Out and about right now :)
                              • squidmaster
                                • Aug 2011
                                • 2666
                                Here's one done back in December. Keep in mind the technology used to datalog is still under development, and may not be exact (for instance it only records RPMs in increments of 10 at the moment). I'll be releasing more as I get the chance to.
                                E30 325i (M20B25) with 272 cam, 19lb/hr, and some mass removed from the flywheel. Also exhaust and stock airbox/AFM. On a 200k+ mile engine.
