Head bolts
  • evil_twin
    • Nov 2007
    • 2965
    Head bolts
    The head bolts are torque to yield bolts... how many times can you reuse them? They are brand new found oht the head was cracked after I installed them. They have zero miles on them. Anyone?
    Sent from my SPH-L720 using Tapatalk
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
    • 34839
    zero.
    a new set is like $25. seriously.
    • Cabriolet
      • 9620
      no bolt that is torque to yield may be reused ever.
      when you tighten tty bolts they plastic deform, an irreversible deformation of the bolt.
      Much wow
      I hate 4 doors
      • evil_twin
        • Nov 2007
        • 2965
        Thank you! Thats what I thought but wanted to double check
        Delta Auto Care
        Herndon, VA
        703.435.1375
          • 34839
          in before a r3vtard posts how he's re-used M20 TTY rod bolts to save $50 on his motor "rebuild". :p
          • jalopi
            • 2370
            Aren't metric blues like, $30-40 and reusable? Seems like the smarter route. TTY bolts are weird imo.
            • Cabriolet
              • 9620
              The McMaster Carr's have a tensile strength of 125,000psi and rockwell hardness of c27
              Metric blues have a tensile strength of 176,900 psi and Rockwell hardness of C38
              The ARP2000's have a tensile stregth of 220,000psi and rockwell hardness of c46
              Originally posted by TS87325IS
              Metric blues are definatley not reusable just incase anybody wants to know..
              also dont use metric blues. i've seen a ton of people that crack them in the block
              Much wow
              I hate 4 doors
                • 34839
                metric blues aren't headbolts. they're some random bolt that happens to have the same dimensions as the M20 bolts. Yes, they've been used. No, I'd never use them. TTY bolts are superior for a number of reasons. if you're going to try something different, go with a stud that's meant to be used as a headbolt.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Again, to save a few pennies in comparison to a rebuild.
                  john@m20guru.com
                  Links:
                  • SkiFree
                    • Jun 2011
                    • 2766
                    ADAMS Autosport
                    • digger
                      • Nov 2005
                      • 6147
                      what was the issue with the original hex head bolts that were "recalled" years ago? was it a fault from the manufacturer i.e. quality?
                        • 34839
                        yeah, they were defective. they weren't TTY I don't think either.
                        • digger
                          • Nov 2005
                          • 6147
                          from memory they were basically the same as any average 12.9 hex head bolt. basically a metric blue but with out the hex socket head
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            They weren't TTY IIRC, but they did require heat cycles between sequences.
                            john@m20guru.com
                            Links:
                            • redlightpete
                              • Mar 2012
                              • 265
                              Actually you might be ok reusing these. Certainly the installation causes some damage to the 'bolts', but this may not be significant. I'd be more worried about the fatigue damage done during countless heat cycles than any deformation during installation.
                              If you had an extra new bolt you could do a little experiment to verify. Just install the bolt using the correct torque-angle procedure and remove it. Do this over and over again until the bolt breaks. Divide 1 by the number of cycles it took to break the bolt. This would be the approximate % of the fatigue life that is used up during installation. So if it takes 50 cycles to break the bolt, you're using up 2% every time you tighten it, and installing it a second time isn't a biggie. If it breaks in 4 cycles, then everyone else is right and you should spend the $25.
                              I used the same two old rod bolts to plastigauge the six rods on my motor. I tightened them with the recommended torque angle method each time. So those tolerated 7 installations with no problems. Maybe If I get motivated I'll go out and perform this test with those TTY bolts and report back.
