NGK plugs
  • E46Twist
    • Aug 2013
    • 167
    NGK plugs
    Hey guys I bought some NGK ZGR5AGPs and the caps won't screw off? I actually broke the pole in one seeing if it was just really stuck. Anyone have this problem with them before?
    "Fast is Sexy"
  • LJ851
    • 7919
    Not all caps are removable.
    Lorin
    The M30 is God's engine.
    • E46Twist
      • Aug 2013
      • 167
      I though the NGKs were.. I bought them listed for this car as well.
      "Fast is Sexy"
      • LJ851
        • 7919
        It should be fairly obvious, the NGK plugs with removable nipples have a threaded hole all the way through the nipple so viewed from the top you see a shallow threaded hole. The fixed ones are solid on the top.
        Lorin
        • E46Twist
          • Aug 2013
          • 167
          Well eff
          "Fast is Sexy"
          • BillBrasky
            • Dec 2008
            • 1641
            Lorin is correct. ZGR5A is the plug number that I use for the m20b25. I don't know what the "GP" on the end of the number means.
            http://www.ngk.com/ngk-aut-c1411.aspx
            • E46Twist
              • Aug 2013
              • 167
              The part that means I wasted $50 lol. Leave it to Orilley's to not know what actually fits the m20. It's right on the website too so its not the workers fault.
              "Fast is Sexy"
                • 37833
                Those are platinum plugs and incorrect for the M20.
                As stated you want the ZGR5A which are usually about $2.70 each.
                Grover Beach, California
                BimmerHeads.com
                • digger
                  • Nov 2005
                  • 6194
                  also BPR5ES work as do BPR6ES, the latter for higher comp engines
                  • Sea Aych
                    • Apr 2013
                    • 765
                    Take some small pliers or a gorilla and twist those caps off and unscrew them. They're on stupidly tight but they do come off with some help. Just did it yesterday
                    1988 Atlantisblau Euro/Japanese 325i Cabriolet
                    1989 Schwartz 325i - now M50 powered! - now very dead
                    1998 Toyota 4Runner Limited
                    My 17,000km Big NA National Parks trip!
                    • digger
                      • Nov 2005
                      • 6194
                      as long as they are the removable type, dont try and remove the non removable ones you will end up with more than just the cap
                        • 34844
                        platinum plugs suck and Orilley's blows. sorry you lost $50 - M20 plugs should cost about $15 at the most. :(
                        • EyExR
                          • Jan 2011
                          • 959
                          return them
                          My 325iX DIY Threads:
                          Front Wheel Bearing Replacement
                          325iX Rear Subframe Bushings and MUCH more w/pics!
                          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                          • E46Twist
                            • Aug 2013
                            • 167
                            They were nice about it and switched me out for the right plugs. I am surprised more people havnt had this priblem and Orilley's hasn't changed that. Does the m42 take the newer plugs?
                            "Fast is Sexy"
                            • LJ851
                              • 7919
                              "Fast is Sexy"
                              Ah, it's all coming back to me now. The last time i went to o really for e30 plugs they sold me platinum or some other pencil dicked bullshits with fixed caps. Took them back for the correct plugs and told them to fix their parts listing since you actually could not use them on the car with OEM plug wires.
                              Apparently they did not listen to me.
                              Lorin
