tooothed cam gear harmonic balancer
  • paperboy91
    • Aug 2013
    • 83
    #31
    Originally posted by digger
    after having seen that failures are getting a little more common i was thinking the same.
    solution was to by a brand new front that has seen no fatigue cycles and no heat cycles. mines for a big stroker with lots of revs so didnt wan to risk it
    shouldn't be seeing too much heat i would think. but they are 25 year old, and essentially a rubber part.
    how much did you pay new?
    • TobyB
      • 5266
      #32
      It's not a heat thing, it's a vibes thing.
      The flywheel dampens the back of the crank, but that leaves the nose floating-
      so the front dampener acts as an 'anti resonator' to prevent the nose from building
      up vibration and shaking itself apart. The rubber ring lets it move some- but then 'catches'
      it at the right phase of its oscillation to prevent it from breaking the crank.
      It's a big deal on big block v8's, too...
      t
      • digger
        • Nov 2005
        • 6148
        #33
        anything under the bonnet sees alot of heat especially between the engine and radiator.
        rubbers dont like heat they fatigue a fair bit easier.
        all rubber parts that see stress have a finite life, the heat lowers this, it is just the way it is
        • paperboy91
          • Aug 2013
          • 83
          #34
          Update: got a balancer from Banchwerks in Ri's Tim. great guy. gave it to me for free! car started right up and I even drove it for the first time. here's hoping it doesn't decide t comeapart when I do timing belts in the future! Cheers guys
