Check engine light after M30 AFM and intake
  • mazzo
    • Jul 2014
    • 264
    Hi all,
    I have put on 19lb injector, Variable fuel pressure regulator, weber fuel pump and MarkD chip. The car was running fine except maybe a bit too rich.
    This morning I install the M30AFM with cold air intake, and I start getting check engine light after several miles of driving.
    Any idea what could went wrong? Am I running too lean? Do i need to adjust the throttle cable or fuel pressure regulator?
    Thanks in advance for your help!
    Matthew
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • Gregs///M
    • Mar 2012
    • 2459
    What's the check engine light code?
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • mpowerful
      • Jul 2013
      • 1273
      Ditch the m30 afm and the adjustable fpr and try again.
      • sayed ali
        • 762
        M30 afm is a drop-in upgrade but usually you need to adjust it little bit .. if you have an adjustable fpr then it's a good idea to play with that too ..
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
        • digger
          • Nov 2005
          • 6194
          is the chip for an M30AFM'd m20?
          • george graves
            • 20003
            ^edit - digger beat me to it.
            Something tells me you're operating outside of what MarkD sells the chip for. No?
            You can't just throw parts at things and expect it to all work together automagically.
            MarkD sells a chip that is set up for a very specif combination(depending on what you buy, is what you get). Throw a few random parts into the mix, and it won't work. It's not his fault - it's just very limited.
            Originally posted by Matt-B
            • digger
              • Nov 2005
              • 6194
              this is for m30 AFM
              http://sssquid.com/v2/shop/e30/e30-325i-with-m30-afm/
              http://sssquid.com/v2/shop/e30/e30-2...p-for-m30-afm/
              • mazzo
                • Jul 2014
                • 264
                Hi all,
                The fault code is 1222. So maybe I have a leak, or I am running too lean, or something else? Thanks for your help in advance!
                Matthew
                Current:
                Past:
                '06 325i Black 5sp
                • mazzo
                  • Jul 2014
                  • 264
                  So using M30 AFM requires a different chip? Is that right?
                  Matthew
                  Current:
                  Past:
                  '06 325i Black 5sp
                  • mazzo
                    • Jul 2014
                    • 264
                    Leaks....
                    So it seems like my intake hose from the AFM to the throttle body was cracked. Good that I have a spare one (yes I brought a spare one just in case, now comes in handy) and redo the whole setup. I've driven the car for ~20 miles now and no check engine light thus far, so I hope the leak was the issue :)
                    Current:
                    Past:
                    '06 325i Black 5sp
                    • squidmaster
                      • Aug 2011
                      • 2666
                      Yes, the M30 AFM requires a specific chip to have it running right. The registered airflow to voltage in the M30 AFM is not the same as the M20 AFM. This will lead to fueling that is incorrect which could lead to damage over time.
                      • uturn
                        • Dec 2010
                        • 1006
                        The true underlying issue... did you check if you swapped the m20 out for a m30 to go with that AFM?
