Everyone's Favorite Subject (Oil)
  • lukeADE335i
    • Apr 2013
    • 1389
    Penrite HPR10 - full synthetic 10W50.
    Cheap down here as it's Australian oil - good product.
    My e30: OEM+ with M30B35
    • Bullhead
      • Sep 2014
      • 532
      I will tell you one thing though. If that LiquiMoly goes on sale again a BA I may buy a couple gallons of it. I have heard a lot of good things about it.
      sigpic87 325E The Honey Badger
      • 3vilE30
        • Jan 2013
        • 344
        LiquiMoly is some good stuff, look for their mos2 anti friction blends. Probably the only oil I would run if I had a built m20.
        • mitchlikesbikes
          • Dec 2013
          • 858
          i ran 15-50 mobil1 from wally world and beat the living piss out of my car for a summer with no issues. probably going to do the same again this coming year.
          IG: @mitchlikesbikes
          • LowR3V'in
            • 4209
            20w50
            BUT!!
            recently I discovered that is way to thick for cold starts
            so probably a 5w40 is more acceptable.
            Just have to get an oil pressure gauge and test it out.
            • digger
              • Nov 2005
              • 6215
              despite what the 25yr old manual says i would never use 20W-xx ever on an engine that sees lots of cold starts, the oil pressure when cold would be through the roof which typically means you are getting less flow on a cold engine. and you know what they say about when most wear happens.....in any case any differences between oils will take a loooong long time to show up so using an oil for a few years without issues means basically nothing, except perhaps pertaining to cam lobe wear but that's not a viscosity thing.
              an oil temp and pressure gauge will go along way to tell you what is good for your application
              i also am a fan of penrite
              • LowR3V'in
                • 4209
                ^so what are you using?
                • raudonis
                  • Jan 2013
                  • 184
                  Autodata specifies semi synthetic 10W-40 for all m20s. Of course this is bare minimum. Full synthetic is always better than semi or mineral. For people bitching about it being an old engine I have 1 thing to say - m20b20 from 1977 and m54b30 from 2006 run exactly the same main bearings and conrod bearings with exactly the same tolerances, go figure.
                  My transaction feedback on r3vlimited :):Clickety click
                  • estoguy
                    • May 2013
                    • 1087
                    With that Castrol Edge 5w50, I've had no cold start issues. It's 5w for the cold starts, but still a 50wt oil. I run it all year. last year, we had an extremely cold winter here in Ontario, and I had no problems. I stick to the following for my start up routine: Start, let car idle up to 2 minutes, depending on ambient temperature. I start off slowly, keeping revs below 2000. Once in 5th gear, I keep the car around 1500-1700 RPM. Now I'm a bit more anal here. I wait until the temp gauge gets to the first thin white tick before driving normally. I know that the "normal" temp range is anywhere beyond the blue, but like I said, I'm anal about it, especially in cold temps.
                    Estoguy
                    • slothonaleash
                      • Sep 2014
                      • 88
                      300k+ mile m20b25:
                      20w50 castrol dino when it's warm/hot outside
                      10w40 when it starts to dip below 40 degrees F or so--really helps out with cold starts.
                      Frequent oil changes
                      I'll be switching to synthetic after a rebuild! (Amsoil if I can get my hands on it)
                      I wait until the car is well out of the blue on the temp gauge to go over 1/4 throttle.
                      • Lugnuts
                        • Oct 2014
                        • 136
                        Freshly rebuilt engine. Running Redline 5W-40. Seems to do the job. Don't have much to compare it to.
                        Thinking I'll switch to Penrite 10W-50 at the next change.
                        • Kevinl
                          • Oct 2012
                          • 897
                          Delvac 15w40
                          1989 BMW 325is Lachsilber metallic 5 speed
                          2007 BMW 335i KARMESINROT 6 Speed manual
                          2011 BMW X5 35I
                          • indecline
                            • Sep 2007
                            • 244
                            After reading some of the informative responses... going with 10W40 Mobile/Royal Purple
                            1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
                            • mtnbimmer
                              • May 2012
                              • 73
                              After reading most of the uninformed responses, I'll stick w/M1 0W-40.
                              • dnguyen1963
                                • Nov 2011
                                • 2651
                                Farm and Fleet 15W40 diesel oil works fine for me...$8 per gal.
