Which injectors should I get?
  • E30_Narek
    • Sep 2014
    • 398
    So I'm looking at changing my injectors and I was wondering which ones are good. I heard E36 injectors are common swaps from the stock M20 ones, but I just wanted to make sure. So, could anyone suggest which injectors I should get for my M20? If you could provide a link or two that would be great.
  • digger
    • Nov 2005
    • 6193
    if there is actually something wrong with yours then something close to stock flow is recommended unless you have a chip that stipulates a certain type of injector
    • E30_Narek
      • Sep 2014
      • 398
      Nothing's wrong with mine. Just thought maybe putting a bit bigger injectors on my car would slightly help with performance.
      • digger
        • Nov 2005
        • 6193
        nah leave it alone you wont gain anything meaningful over a good condition set of stock ones
        • E30NJ
          • Aug 2013
          • 921
          Say your ran a chip, just for example, the $30 one on eBay. Then should you get larger injectors? Like the 19 lbs ones from the M50?
          • digger
            • Nov 2005
            • 6193
            only if the chip "maker" specifies it.
            • dnguyen1963
              • Nov 2011
              • 2651
              Bigger injectors without proper chip is like inviting trouble makers to your party.
              • E30NJ
                • Aug 2013
                • 921
                Ah gotcha guys. Thanks for thanks clarification!
                • packratbimmer
                  • Dec 2009
                  • 1335
                  Your car will likely run rich if you do not match your injectors to your chip tune.
                  • digger
                    • Nov 2005
                    • 6193
                    the ECU can compensate to some extent, but where i am coming from is why you would change from a perfectly functioning part to something that is not properly matched and offers no tangible benefit....
                    if they are stuffed and its cheaper to get a slightly bigger set then fine, the engine should run ok if it has been well maintained, hell i ran a 19lb set for a few weeks while doing some troubleshooting and it ran ok, its far from ideal and wouldnt do it longterm without a chip programmed with them in mind
                    • 95BMWIC
                      • Apr 2012
                      • 353
                      Contact this guy:
                      I highly recommend him.
                      • packratbimmer
                        • Dec 2009
                        • 1335
                        Yes - I have had good luck with MEPEH injector service too!
                        If you do not have a chip upgrade yet you will feel a major difference with one. You could actually feel little to nothing by "upgrading" injectors without a proper tune.
                        I am going to try a SSSquid chip when I get the account built up. They tune to the specific injector.
                        • EatsHondas
                          • Sep 2012
                          • 404
                          MEPEH (Dmitri) and SSSquid are awesome. I ran SSSquid's 91 octane chip for the 173 DME before I installed Megasquirt. Definitely a noticeable difference in power.
                          1989 325i Lachssilber Sedan
                          5-Speed Swapped
                          M30B35 Swapped
                          MegaSquirt MS3X
                          1987 325i Lachssilber Sedan
                          260k OEM Automatic Daily Baby
