Intake AFM horn- don't touch it!!!
  • Klug
    • Sep 2011
    • 804
    After looking into an issue I've had since owning the car, whenever I was at idle and blimp the throttle with my hand- I always had a short hesitation before it started to rev up. Checked all vac leaks, every fitting and what not over the years. It always had this and I figured it was just how the M20 is.
    I recently was overhauling my intake and noticed that reading a few threads that there is an AFM intake horn in the airbox. Being that I never had one or it was removed by a previous owner I figured it wasn't a big deal. I found one in a junked m20 and installed it- damn the hesitation completely stopped! It apparently helps with Throttle flutter and gives the AFM a steady constant stream of air intake.
    Do yourself a favor, if you don't have one installed- find one. If you have one and want to delete it...don't.
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
    • 34844
    people take it off thinking they'll make more power. nope...
    • packratbimmer
      • Dec 2009
      • 1335
      + 1! ^ Leave it alone.
      • ForcedFirebird
        • Feb 2007
        • 8300
        We tested it on the dyno. Minus 4hp at the wheels. About what you gain with a generic chip.
        john@m20guru.com
        Links:
          • 34844
          ^lol
          so, they actually did feel a difference then! only what they thought was a couple HP bump ended up going the other way :p
          • ForcedFirebird
            • Feb 2007
            • 8300
            It just gets louder. This is why I don't trust butt-dynos. ;)
            john@m20guru.com
            Links:
            • digger
              • Nov 2005
              • 6178
              would be better with a shorter horn that isn't so close to the front wall. however removing it altogether leads to a sharp edge on the entry and bugger all distance for the flow to be straightened before hitting the barn door so its not surprising that it doesn't help
              • packratbimmer
                • Dec 2009
                • 1335
                Makes ya wanna get a MAF!
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  No, it doesn't. Specially if the MAF is hacked onto the stock ECU.
                  john@m20guru.com
                  Links:
                  • Hooffenstein HD
                    • Nov 2012
                    • 1388
                    Yep.
                    I've had an awful cold start idle since the MAF swap and killed a couple of genuine Bosch MAF sensors in ~6 months.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Originally posted by Hooffenstein HD
                      Yep.
                      There's nothing wrong with the stock ECU and functioning/fresh components. We put these cars through rigorous endurance races and are always amazed at how reliable the stock parts really are - even being 20-30yrs old :)
                      john@m20guru.com
                      Links:
                      • Zalmoxis
                        • Nov 2014
                        • 68
                        Guess what I'm doing tomorrow morning ? Thanks for the post !!!
                        • Sps
                          • Apr 2013
                          • 265
                          I went maf and never looked back. Much snappier rev.
                          ATTENTION:
                          FOR THOSE WHO HAVE NOT DONE SO, PLEASE DO SO AT THIS TIME
                          • Madhatter
                            • Oct 2004
                            • 966
                            no problems with my MAF either. If you are killing them I would be suggesting you look at how healthy your motor is. Aside from doing something stupid like trying to clean it, usually the other thing that kills them is if you have a lot of blow by and end up with plenty of oil vapour in your intake.
                            Just a little project im working on
                            - http://www.lse30.com -
                            • pbsun
                              • Jul 2011
                              • 97
                              Even with that horn i have a slight delay
