160 whp attainable on a basic m20 build?
  • digger
    • Nov 2005
    • 6147
    by build i'm assuming you are freshening the bottom end in which case its easily achievable with custom tune.
    • 2mAn
      SeƱior Mod
      • 20830
      Originally posted by digger
      by build i'm assuming you are freshening the bottom end in which case its easily achieveable
      a "build" here usually means stanceworks coils and ESMs. I highly doubt the head is coming off. this build seems more like "160whp attainable on a basic m20 bolt ons"
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • f2740xd
        • Aug 2015
        • 19
        head is already fresh; new seals, resurfaced, etc..
        • digger
          • Nov 2005
          • 6147
          what does the engine baseline at now? that will tll you how much more you need
          • f2740xd
            • Aug 2015
            • 19
            very good point, and the answer to that is unknown. just read through your build thread and man is your setup sweet. goals x10000
            • digger
              • Nov 2005
              • 6147
              Originally posted by f2740xd
              Okay, then I won't worry about the fw for now, would rather spend the 220+ship from rhd on a tune, that'll prob come longer down the road unless I'm feeling spend and splurge. Don't want to spend more than 1200 all in on performance mods. Could kinda do a turbo build with the 780$ cx kit, tcd 179$ tune, $180 for a wideband, and blue top bigger injectors running 8 psi (ish), but not sure how I feel about that (would be on stock hg and bolts). Any input as to that?
              ... oh and a couple hundred to have a down pipe made
              also don't know what the deal is with the fuel pressure regulator... is the stock one useable on low power levels?
              a light weight fw will make a big difference in 1st and possibly 2nd gear where the rate of change of engine rpm is greatest the car will acclearte noticeably faster, to not do it because it may not produce more power on the dyno seems like a strange idea. are you trying to build a dyno queen? usually you do modification to make the car accelerate faster more often than not the dyno picks this up but not always. there are also things that make more power on the dyno but dont really make the car accelerate faster
              • TobyB
                • 5266
                ...the lighter flywheel makes it more fun to rev- match, too...
                t
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Yes it does. Makes for a horrible tuning session with wind down though :(
                  john@m20guru.com
                  Links:
                  • f2740xd
                    • Aug 2015
                    • 19
                    nevermind, search found my answer to question edited out.
                      It is possible to get 160rwhp on a DynoJet from a fully stock M20B25 engine. Doing so requires balancing of all moving parts, swapping rods/pistons around to get the most uniform deck height, precision rebore and precise matching of piston diameters to the bores, a three angle valve grind, matching of valve springs, and a new or blueprinted cam. You also need a fresh ignition system and professionally cleaned and rebuilt injectors.
                      We decked the head to the max to slightly raise CR and modified the cam sprocket to bring the cam timing back into spec. A minor tweak of the CPS mount was used to slightly advance the spark timing.
                      That engine in my Spec E30 pulled 161rwhp on a DynoJet on a 100F day. The numbers would have been slightly higher on a cooler day.
                      • Bearmw
                        • 1323
                        Great info Jim.
