Das Beast: My E30 track / street build
  • zwill23
    • Jul 2015
    • 615
    #166
    The block is looking great! I imagine it will be going back together very soon
    • dvallis
      • Oct 2015
      • 1474
      #167
      For sure. On the uphill slop to re-assembly now. Ordering cam, valve springs, HD rockers, gaskets, adjustable cam gear, head studs, crank scraper and oil pan baffle. Pistons are almost done getting matched to the stroker crank. This is the interesting part. ;-)
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • 2mAn
        SeƱior Mod
        • 21062
        #168
        seriously you need to move this to the right forum so everyone can see all the work you're doing. this is happening the wrong place and its being overlooked by so many
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • dvallis
          • Oct 2015
          • 1474
          #169
          Simon, I would LOVE to move this to "M20" but have not heard back from an admin. Do you know one personally. HELLO!? PAGING ANY ADMIN! Please move this thread to "M20". Thanks in advance.
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            #170
            Paging Agent, JasonC, James Crivellone, moderator-Masha.M, Jparkr or Admin. Sent you a PM. Please move this thread to "M20" Technical Forum.
            Thanks
            2002 E39 M5
            • sonomabimmers
              • Dec 2015
              • 802
              #171
              just read this in full. WOW
              i love bmws
              • digger
                • Nov 2005
                • 6203
                #172
                Did you measure the deck height, you have it listed as 206.7mm I've measured a few and I think 206.2mm is closer to the mark. The 206.7mm is the stack height ( rod+throw+piston compression height) but piston sit above deck by approx 0.5mm
                • crappycoco
                  • May 2014
                  • 250
                  #173
                  • dvallis
                    • Oct 2015
                    • 1474
                    #174
                    Digger, have not measured it yet. Getting to the "clean room" assembly stage now so that's in my plan. I've seen conflicting info on 206.7 and 206.2 so will be interesting to put it to bed. If it ends up being 206.2 I'm still golden, because the crank/rod/piston compression height is 206.2. (Going from memory) Compression will increase a bit due to lower combustion chamber volume, but I've got a .120" MLS head gasket to compensate. Will post the results.
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #175
                      Mid Day Engine Porn
                      Rebuild parts have started arriving:
                      Schrick 284/272 billet cam (0056 01 840 00) Increases valve lift over stock by 1.3 mm on intake and 0.9 mm on exhaust.
                      Schrick 002 02 090 single coil valve springs: 95 lbs @ 11.5mm lift vs. 75 lbs @ 10.5mm lift for stock.
                      2002 E39 M5
                      • MVincken
                        • Sep 2015
                        • 75
                        #176
                        Awesome work man!
                        Love the preciseness on your engine build.
                        • estoguy
                          • May 2013
                          • 1087
                          #177
                          Wow! Great work! Read the whole thread yesterday. Wish I had time and money to devote to a project like this.
                          Estoguy
                          • dvallis
                            • Oct 2015
                            • 1474
                            #178
                            It's affordable if you do the work yourself. Can't avoid some new parts costs (cam etc) but there are a lot of cheap parts on Craigslist if you are patient and look every day. My stroker crank was free, 130mm rods $40, suspension $200, block paint $30. The parts guy at Korman even joked "Wow. You're really squeezing the cost out of this." Well, any fool can throw a truckload of money at a car. I'm just spending where it counts. The Big Money will be roll cage (because you don't scrimp on safety) and a Canyon Crusher turbo kit, because it just works. :devil: Anyway, it's a great hobby. I'm looking forward to building the racing dash and making a lightweight custom wiring harness. Will post how-to instructions for these as well.
                            2002 E39 M5
                            • sonomabimmers
                              • Dec 2015
                              • 802
                              #179
                              ^^ +1. i moving to austin in three weeks hopefuly i see this beast at the raceway sometime! :coolphoto:
                              i love bmws
                              • estoguy
                                • May 2013
                                • 1087
                                #180
                                I've been in the market for an engine, even an unmodified Eta that I could do a refresh/rebuild on, so I can have it ready to install when my original Eta says it's time to go... but right now, she's at 439K km and is showing no signs of slowing down.
                                Talking to a guy outside Toronto from a Canadian forum who is selling a stroker... needs to be put back together and a some parts, but just might be the ticket. He's given a couple options, running it either N/A or turbo. I'm still new to performance type stuff - my main concern, since my E30 is my DD is that things are reliable, but I'd love to be having more fun than I already am. :) And I'm definitely not afraid of doing my own wrenching... this car has only seen a shop 3 times since I've owned it. All the major work I've done.
                                Estoguy
