Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1666
    Digger, I don't remember ever seeing a rotor adapter. Whats it look like? Maybe just add a washer?
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • digger
      • Nov 2005
      • 6145
      #1667
      Suitable sized Washer will do, rotor adapter is the 3 pointed thing the rotor button bolts to.
      • dvallis
        • Oct 2015
        • 1474
        #1668
        #7. It's long gone. : - ) Washer it is.
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1474
          #1669
          Getting Close
          Getting near putting the engine back in. Finishing off the plumbing today.
          Had Ernie's Welding make this for us. 1.5" aluminum joiner with 4AN weld bung. This is the return for turbo water supply.
          It routes to the water pump intake. Used a couple of off the shelf Conti formed hoses (62116 and 60663) to finish it off. Perfect fit.
          Rebuilding the waste gate. One of the hose fittings penetrated too far and punctured the diaphragm.
          New diaphragm attaches to the valve shaft with grub screws. Don't forget the loctite.
          Pre-turbo oil filter. Just a bit of insurance.
          Here's the final plumbing. Water supply from the water jacket drain with M14x1.5 to 4AN fitting, to turbo then to water pump intake. Oil from sandwich plate, to filter, then 40 psi oil pressure regulator (return to pan), then to turbo and drain to pan. It's cleaner than the last design since everything is engine mounted. Still looks like an octopus mating with the M20.
          Intake manifold, old gaskets and test plate bolted on.
          SMOKE TEST! We're just looking for any obvious leaks. (i.e. oil pan)
          Yes. There is smoke in there.
          It took 60 psi of compressed air and we didn't see a single leak.
          Next time we'll strip everything off, rebuild with proper torque and final gaskets. Then it's going back in.
          2002 E39 M5
          • Elysian
            • 674
            #1670
            Awesome!
            • zwill23
              • Jul 2015
              • 615
              #1671
              Wonderful!
              • dvallis
                • Oct 2015
                • 1474
                #1672
                Time to get caught up on the blog. Had the flu for a week, work got busy but we've finally been making good progress.
                Quick recap. Long block built but not dressed
                When you install the intake manifold, bitch tube goes on FIRST. #facepalm
                Like this.
                We noticed blow-by on the old exhaust manifold gaskets, probably improper torque since the bolts are a @#$#@ to reach. It was still a bitch to torque, even with the block on a stand but waaayyyy easier.
                Flywheel and clutch installed. I was worried about the holding torque at first but it was just break-in. Holds like a beast.
                Now for this part of the adventure. We tried installing the engine with transmission attached. With the stock oilpan engine measures ~31 inches from rear top of head to bottom front of oil pin. It will JUST fit into the bay and slide home. We found out that the new and improved oil pan adds about 3 inches to that measurement. Which will NOT fit into the engine bay. You might be able to do it hanging the engine almost vertical and doing the dance. Our shop ceiling is too low, cherry picker not tall enough and we don't trust the Harbor Freight leveler that much. Foooooook!! That was a rough day. We were literally exhausted.
                Sooooo .... Transmission off, drop the engine in, not quite onto the frame, still hanging by the cherry picker. We pulled it all the way forwards to give ourselves room to work on transmission bolts.
                Car is on ramps at the front, jackstands at the rear. Still had to jack it a bit to slide the transmission under.
                Jack the transmission and stab pilot bearing. It's a pain in the ass, but do-able of you leave slack on the engine to move a bit. Locate the pilot shaft inside the clutch plate center hole, move it and the engine around by feel until the pilot shaft slides home. You have to get the transmission angle just right. Use the transmission housing face and block starter ring to judge co-planarity. Once its in, use the four transmission bolts as guides to snug it home. Whew.
                After that, transmission bracket, drive shaft carrier bearing, drive shaft front and rear bolts went on fine.
                Drivetrain done. The rest of re-assembly is pretty easy compared to all that. Back on the road soon for a new tune at Boot Logic.
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1474
                  #1673
                  Garrett turbo transplant in progress.
                  Relocated boost controller. Turbo compressor shroud wasn't ported (whaaa?) so we created a new boost reference downstream.
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1474
                    #1674
                    Glad we built the turbo hoses with the engine on a stand
                    Turbo install complete, minus a 2.5" clamp for compressor output. We're going to leave the cover off the airbox. It's a good splash / dirt guard but will breathe better with the top open.
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1675
                      Das Beast 2.0
                      Getting there. Lots of work planned for this holiday long weekend.
                      We ditched the air box altogether. I really like the new look.
                      Cold side was easy to reinstall. We moved the IAT sensor to a welded bung near the BOV.
                      Close now. Rad goes back in tomorrow then down on the floor for a compression check. Rings aren't broken in but it won't make a huge difference at 100 RPM. It's just a sanity check.
                      Back on the road .... soon.
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #1676
                        Close only counts with hand grenades
                        You'll get what I mean in a minute
                        Moving on, getting the new rad hoses in place. Note the turbo water return bung
                        Everything done. We had to put the turbo intake filter angle back on. It was running into the rad.
                        Add 10 quarts of break in oil. Yes, really. 10.
                        7 QT = tip of dipstick
                        8 QT = low mark
                        9 QT = half full
                        10 QT = full mark
                        We are truly frigging cursed when it comes to priming the oil system. Some of you might remember when we dropped a socket into the oil pan when priming the last time. Oh the horror. This time it was the intermediate drive shaft. Got it out with a magnet stick and flexible grabber tool. Damn I hate this part of the rebuild.
                        Spin the shaft clockwise with a drill for a couple of minutes to prime the system. We got 60 psi.
                        Got to be time for the compression test. We lit up the panel, crossed our fingers, pressed the START button and . . . Nothing.
                        The starter was jacked. When we installed it I felt something give when connecting the solenoid to its drive wire. Too much "Farm Boy" which I always give Rob grief over. This time it was me, shearing off the solenoid post internally. Ugh.
                        New starter gets here Tuesday. Commonly found as Bosch SR443X on Amazon, eBay etc. The ROEM starter part numbers seem to be rare or NLA.
                        So close, but . . .
                        Now you get the title
                        2002 E39 M5
                        • McGyver
                          • 4634
                          #1677
                          Awesome progress, I can't wait to see the results of the new turbo! Too bad the starter died, but at least its an easy fix!
                          • dvallis
                            • Oct 2015
                            • 1474
                            #1678
                            It's Alive!
                            First start. Ran like a champ. Frigging static compression is 180 - 200. Yikes!
                            2002 E39 M5
                            • Elysian
                              • 674
                              #1679
                              Awesome!!!!!
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5246
                                #1680
                                It sounds happy to be running again
                                Originally posted by priapism
                                Originally posted by shameson
