Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #376
    More Body Shop
    Time to get down to business. Ended up with a gallon can of this stuff ... Everglass short strand fiberglass / kevar body filler. Very similar to 3M MarGlass. Got it from an auto body repair wholesale supply shop. It's very strong and can take some flexing. This will be the base layer.
    Here's the proportion of hardener to filler. Once mixed you only have 5 minuets to work it. That's the downside from regular bondo.
    Work in progress. Don't try and work MarGlass when it starts to harden or you get the crocodile skin look.
    Front fender done. I got the hang of it at the end, towards the front. It's smoother. :devil: Nothing a sanding block and some more regular filler can't take care of.
    Here's the rear with fuel filler delete. Fuel cell will have a trunk deck filler.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1474
      #377
      More Das Beast Body Shop
      Sanding, sanding, sanding, sanding, sanding ..............
      Front is looking better. Still needs a filler slick coat and more sanding to get rid of pinholes and voids.
      Liking the rear. Will never tell there was a filler plate.
      Other side done.
      ......... 4 hour upper body workout. Damn I am sore! :devil:
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #378
        More Body Shop
        Next step is a slick coat of regular bondo. It's not as strong as bondo glass, but is doesn't have to be. This coat just fills in surface holes. Bono gets a bad rap because people use the wrong type for a job. For instance, use if I used this slick coat as the flare structural base I'd be asking for trouble. It would soon crack and fall off if you built it up to any thickness.
        So, here's the slick coat before sanding.
        After sanding. NOW we're getting somewhere. Looking and feeling very smooth. This is with 80 grit sandpaper.
        Next coat will be bondo glazing putty. Fills in even smaller holes. Then sanding with 180 grit. Then wet sanding with 220 grit.
        Man. Body work is totally OCD. :devil:
        2002 E39 M5
        • 2mAn
          SeƱior Mod
          • 21080
          #379
          Loving the progress! Love the wheel choice, hopefully they arent too heavy
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Digitalwave
            is a poseur
            • 6301
            #380
            Don't you think you should have done the body work with the trim removed, so it's removable in the future?
            RISING EDGE
            • dvallis
              • Oct 2015
              • 1474
              #381
              The flares are mode to overlap the trim. I could have cut the trim and made it removable, but I'd have to engineer a new clip system. Not worth the time. And I like the blended look. Center trim is still removable.
              2002 E39 M5
              • dvallis
                • Oct 2015
                • 1474
                #382
                Wheels are 20 lbs. Not feather light, but I'll take it for $100. Getting rims 4 lbs lighter costs $1500 more. Not a great ROI.
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1474
                  #383
                  Das Beast Arctic Body Shop
                  So it's 45F degrees in Texas. Obi Wan (Rob) used to own a business that had an in house paint shop. He educated me on the horrors of painting in cold weather. It doesn't work. Paint doesn't operate at that temperature. So ... we had to engineer the hell out of it.
                  Finished the glazing putty coat before Arctic Freeze set in.
                  Before:
                  After. Now it's getting smooth.
                  First step: Build a rig with infrared heaters to warm up each fender to ~100F. Once it's there for about 15 minutes, remove the heaters, let cool to 80F then start shooting with paint. Notice the gun and cup warming up as well. It was COLD.
                  Here's the paint shop setup. 4:1 primer / reducer, shooting with a cup gun.
                  And the end result. Primer really brings out any imperfections. A few spots need rework. After that's done, back to block sanding the primer with 320 grit, do a reveal coat, then block sand some more with 400 grit.
                  Rear quarter. Filler door is gone. :devil:
                  Overall it's going pretty good.
                  2002 E39 M5
                  • 2mAn
                    SeƱior Mod
                    • 21080
                    #384
                    Cant wait to see it with Alpine White paint and the wheels.... or are you painting it a different color?
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • dvallis
                      • Oct 2015
                      • 1474
                      #385
                      Sticking with alpine white and Warsteiner livery.
                      2002 E39 M5
                      • 2mAn
                        SeƱior Mod
                        • 21080
                        #386
                        That's my work computer wallpaper
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • JJ1
                          • Oct 2009
                          • 176
                          #387
                          Great work! You should consider picking up the rear subframe with your cage. It's a known failure point for pretty much every 3 series. And also consider reinforcing the shock towers. They can mushroom. Eager to see the end result!
                          • dvallis
                            • Oct 2015
                            • 1474
                            #388
                            Use The Tools Luke
                            This bad boy is going to save me 1000 hours sanding the rest of the car. 5" random orbital sander. Could not use it on the fender flares with all their compound curves. However, it's perfect for taking clear coat off the rest of the car.
                            6 hours later the whole car was done. Still have some minor things to address with MarGlass, bondo or glazing putty but the major sanding is finished. Time for some final body fabrication. And engine bay is also work in progress.
                            2002 E39 M5
                            • haaken675
                              • Sep 2016
                              • 601
                              #389
                              What kind (thickness) metal did you use for the roof panel? I have a fiberglass delete panel that I was planning to install, but I think I like what you did better as it will be much more flush inside.
                              • dvallis
                                • Oct 2015
                                • 1474
                                #390
                                I used 20 gauge sheet steel. Light enough to work compound curves. Stiff enough to hold its shape.
                                2002 E39 M5
