Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #481
    Sonoma
    Friction coefficient for stock brakes is approximately 0.4. In comparison, the Poly-A pads, Hawk rotors and Wilwood calipers will stop a 1900lb E30 like a battleship main anchor. :devil:
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1474
      #482
      Wife appreciates my new welding skills. Made this package / purse / wife stuff shelf for front porch.
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #483
        We're BACK!
        Finally back to working on the car. Here we are preparing the authentic Z3 2.7 turns to lock rack (See this post: NICE RACK) with a power steering delete block. It recirculates fluid and keeps the rack from binding.
        Next it's time to look at this disaster. Otherwise known as the steering guilbo, or "useless wobbly rubber thing in my steering linkage". It's gotta go. Notice Rob drilling out the rivets.
        Rubber atrocity amputated.
        Now for the good part. We replace the rubber-ness with two x M8 - 2" bolts. Note they must be #8 CASE HARDENED STEEL. You do not want to shuffle off this mortal coil like Aryton Senna with steering failure in some high speed turn. Separate the bolts with 18 steel washers on each side. Finish with Loctite and lock washers. When done, it's a solid steel mass.
        Test fitting before the Z3 rack. Looks and feels great. Note to get that thing on and off, remove the securing bolts, push it UP towards the steering column then remove the lower end.
        2002 E39 M5
        • sonomabimmers
          • Dec 2015
          • 802
          #484
          loving that solid steering linkage setup
          i love bmws
          • badwella
            • 357
            #485
            Cool that you kept the stock linkage. Mine had a crap u joint so I did the double e46 linkage build (back before Garagistic started selling them). It doesn't collapse so it's going to drive my steering into my balls or face if I'm in a head on collision.
            If you don't want to worry about a ton of washers falling out when you undo the linkage, you can probably go to the local hardware store and get bronze or aluminum spacers.
            I know home depot sells some in stores: http://www.homedepot.com/p/10-x-1-2-...5158/204276557
            P.O.S 1989 325is - aka Project Sh*tbox
            Project Shitbox - Restomod and other stuff - soon to be 328is
            • Elysian
              • 674
              #486
              Originally posted by sonomabimmers
              there is a fair amount. i see a couple a day driving around the south side. bmw cca chapter out here is pretty active they do meets and drives.
              Saw a beautiful E28 on Slaughter and So. 1st today. Just mint looking.
              • sonomabimmers
                • Dec 2015
                • 802
                #487
                I see that thing on the daily !!!!! It's beautiful and so oem,basically perfect. I haven't caught the owner yet but he lives down the street from me. We need to make Austin a more active community......
                i love bmws
                • TobyB
                  • 5264
                  #488
                  In for pix of busted steering parts while parallel parking high ratio rack with no power steering!
                  The washer scatter, I predict, will be subtantial.
                  I poke fun, but I do also wonder how strong that stack is in torsion...
                  ...I remember parking the 2002 with 15's, and that wasn't easy...
                  t
                  • peterman
                    • Feb 2015
                    • 173
                    #489
                    So, Toby makes a good point about your washer stack. Because the car had power steering, the use of a guibo works because not much force is going through the steering column. Since you removed the power steering, you will now be responsible for putting in the required torque to turn the wheels at low/no speed. This setup will not be that strong in shear. It has the potential to fail - definitely not saying it will fail, but over time it could. You will also most definitely get some "hmmm?" or "eww" looks from fellow racers who spot the setup while sizing up the competition at the track.
                    A couple of reasons:
                    1. The washers are a free fit to the bolt. An M8 bolt has a washer ID of 8.4mm. Assuming they are not all lined up the same, you will have multiple line loads through out the stack up making an inconsistent load.
                    2. A bolted joint should clamp 2 faces together. The stand off distance would not be a terrible thing if this was a compression or tension application. But since this is a shear or torsion application the use of a stand off needs to be much beefier than stacked washers.
                    3. Grade 8.8 bolts are good but they can still stretch. The washer stack will add a torsion and bending moment to the bolt causing the system to "wiggle" back and forth thereby potentially (probably) bending the nut-washer interface, stretching the bolt and losing your pre-load.
                    There are grade 10.9 bolts out there that would also work and be quite a bit stronger. Additionally, this would be a proper time to use a shoulder bolt and not a fully threaded bolt which would add some additional strength.
                    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                    I would suggest using a proper, solid stand off as suggested by badwella.
                    Although this is a standard size, it is as close as you can get to reamed sleeve for an M8 bolt. It has quite a bit of meat so it will help counter any bending from the torsion load.
                    And just to nit pick it would be an M8 x 50mm, not 2":p
                    It's looking great! Keep it up!
                    Pete
                    • dvallis
                      • Oct 2015
                      • 1474
                      #490
                      Ha! You guys thought we were going racing with that washer stack? :devil:
                      Here's the Das Beast Solid Steering Linkage. Prototpe being machined this week. Who wants one? If I get enough interest will make a batch.
                      2002 E39 M5
                      • ThatM20Guy
                        • Aug 2014
                        • 600
                        #491
                        Any price range estimates?
                        89' 325ix Diamantschwarz/Black rattle can...
                        Insta: r_moose_w
                        Originally posted by flyboyx
                        I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                        • sampayne
                          • Apr 2014
                          • 396
                          #492
                          That would be a nice addition for my upcoming rack swap. Definitely interested depending on price, of course.
                          Originally posted by 2mAn
                          The BMW V6 is the best
                          • dvallis
                            • Oct 2015
                            • 1474
                            #493
                            Thanks for the interest. Will get pricing tomorrow from a few local shops.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #494
                              Update. 3D printing was stupid expensive for some reason, so I'm getting a prototype of the solid steering link machined in 6061 aluminum. It's actually cheaper. Once we like the fit and finish, machine shop will give me a price for small production runs (10 units). Should be ready this week.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #495
                                <Sigh. I wish vbulletin could do tables>
                                Here is my front suspension refresh parts list. Will be scoping it out with Rob this week.
                                Control arm w HD ball joints (left) Myle 31126758513MY $82
                                Control arm w HD ball joints (right) Myle 31126758514MY $82
                                Control arm bushings (Delrin, pair) TMS TSU3080202 $60
                                E36 HD tie rod (left) Lemfoerder 32111139315 $45
                                E36 HD tie rod (right) Lemfoerder 32111139316 $45
                                22 mm adjustable sway bar & bush. IE e30fb22 $225
                                HD rubber transmission mounts (pair) IE e30transmtrbr $40
                                Urethane motor mounts (pair) IE e30urethanemm $90
                                Motor mount reinforcements (pair) IE e30femrefrmnt $20
                                2002 E39 M5
