Das Beast: My E30 track / street build
  • kid8
    • Jul 2013
    • 312
    #451
    Good deal, thanks! Looking forward to seeing how it turns out.
    • MVincken
      • Sep 2015
      • 75
      #452
      Originally posted by dvallis
      "Mess up the aerodynamics"? Are you kidding? The E30 is a damn flying brick. It has aero like a barn door. :devil: Pretty sure my window mod is the least of its worries.
      The e30 has a CW of 0,33 if i recall correctly.
      Which is not bad at all
      • digger
        • Nov 2005
        • 6145
        #453
        its more like 0.38
        • dvallis
          • Oct 2015
          • 1474
          #454
          Paint !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Gentlemen, we have PAINT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Interior, engine bay and trunk got sprayed today. We used single stage epoxy infused primer. Acts as a moisture barrier, primer and paint all in one. Not sure if the pictures do it justice, but it looks spectacular in person. Enjoy.
          "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
          1987 E30 3L Turbo Stroker Das Beast
          2002 E39 M5
          • Digitalwave
            is a poseur
            • 6299
            #455
            Damn, that looks fantastic.
            RISING EDGE
            • wworm
              • Dec 2016
              • 1719
              #456
              This is so exciting
              1984 Delphin 318i 2 door
              • dvallis
                • Oct 2015
                • 1474
                #457
                Exciting for me too. :devil: Shop owner took it as a "special project" himself. He's resanding the fenders for a better body line before we shoot primer. Might even be tomorrow.
                2002 E39 M5
                • peterman
                  • Feb 2015
                  • 173
                  #458
                  "Mess up the aerodynamics"? Are you kidding? The E30 is a damn flying brick. It has aero like a barn door. [emoji317] Pretty sure my window mod is the least of its worries.
                  I think you would be quite suprised at the extra low pressure area and drag you will be creating by doing this mod. You will have enough power to overcome it. You are certainly not building a "momentum car" but you may have some trouble keeping the rear end in check, it will be tough to guage whether that is due to so much power, suspension, or aero, though.
                  Sent from my SM-G935V using Tapatalk
                  • dvallis
                    • Oct 2015
                    • 1474
                    #459
                    Ah, E30 aerodynamics. Kind of like discussing religion. Fortunately, aero is engineering and that's not subjective.
                    E30 has a CD of 0.38 and a rear window angle of 40 degrees.This research paper shows that while increasing the rear window angle does increase CD, after 45 degrees the curve flattens out.
                    The graph also shows why BMW engineers modified the rear window line of the E30 M3. By decreasing rear window angle by 10 degrees, they moved CD from 0.38 down to 0.33.
                    So my rear window mod might add 0.01 to the CD, which is no big deal. Roofline vortex generators can have a much larger impact, so I'll test those once the car is rolling.
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #460
                      Quick update. We had some minor paint drama. "Alpine White" did not turn out right. Bad pigment or formula mix up. Neither the shop or I like the results so we're re-painting. Need to let the car sit for a week so the paint completely cures before we paint again. Shop owner is being very cool about it, so I'm just going to Zen out. We pick up the car next Tuesday.
                      2002 E39 M5
                      • nameisbauer
                        • Nov 2012
                        • 76
                        #461
                        Subscribed. Local and would like to see this real life someday. Nice work.
                        • dvallis
                          • Oct 2015
                          • 1474
                          #462
                          Thanks. PM me and will invite you over to the shop.
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            #463
                            The Beast is back
                            Paint is finally done. Well worth the wait though. Paint guy did a great job on final finish for the fenders.
                            Ready to roll back into the paint booth. Notice it's not quite white.
                            Out of the paint booth. Now THAT is white.
                            And finally back at the shop.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #464
                              Finally back to building the car. Will be using Massive Lee's brake kits:
                              Hardware for 300 x 22 front
                              Plus Willwood 4 piston calipers
                              with Hawk vaned and slotted rotors.
                              Should be lots of stopping power. Talking to Lee about rears now.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #465
                                Had a call with Massive Lee to discuss brakes today. Since his rear kit uses a 1.25" vented rotor for cooling, we are going with 1.25" on all 4 corners. Just need to swap out the 0.81" hats for ones with a different offset and everything else stays the same.
                                Lee's template shows 12mm inside clearance so I'm good to go. That flat white piece is simulating my 10mm spacers.
                                2002 E39 M5
