Originally posted by dvallis
View Post
Das Beast: My E30 track / street build
ST2 for an E30 is pretty crazy! Going to be running with some wicked fast cars.
John, what about the current rules would deter doing the "max power from 2,000 - 8,000 RPM" that you described? You can use average numbers if you want, or you can still claim just 1 peak number for ST/TT as long as it fits in the HP:WT for the class. Average actually works in your favor as it should lower the number. Still seems like you could use that de-tuned V10 method if you wanted.
Yes, our ST2 aspirations could be highly delusional. :-) Flash forward to Rob on the radio yelling "Drive faster!" Alternative is detune to 10 psi and load up with sand bags for ST3, LoL"And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
1987 E30 3L Turbo Stroker Das Beast
2002 E39 M5
The rule change was actually GTS, my bad. Had to look at the Dyno rules for the classes. The way it's done now, each RPM number has a weight to it (xx power at 3000, xx power at 3500, xx power at 4000 etc, max RPM, max power RPM etc) and it gets run through a calculator to spit out it's corrected HP/WT...
NASA GTS Drivers, Please review the message below. I can be reached at bcohn@drivenasa"dot"com if you have questions. 1. NASA feels there is a high potential of unfairness and potential for cheating in GTS by way of detuning to run in lower than expected class. (Consider a detune of more than 50 ...
Went for my first drive yesterday in the newly dyno-tuned car. Wow! What a difference. With our previous "butt tuning" the engine ran strong but felt rough. Now it's super smooth.No hesitation at any RPM and the power comes on like a freight train. When you hit 4500 RPM it slams you back into into the seat like a punch in the chest from Mike Tyson. Had a long time BMW shop owner friend in the passenger seat and he was grinning like a maniac. I was fascinated by the change in boost behavior. With open loop the turbo seemed to meander its way to max boost. With closed loop control the boost gauge instantly snaps to target boost once you get around 4500 RPM.
I'm really happy with how the build turned out. Only gets even more fun from here.Last edited by dvallis; 02-07-2020, 02:51 PM."And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
2002 E39 M5
- Likes 3
Such a great feeling, isn't it?
Up here Georgia racing the 14hr, one of the team drivers is the current TT3 record holder for HMS and SIR. He said the same rules apply for TT as GTS as far as avg HP. The Dyno classification form has you record the RPM at max HP, then the power at 250 RPM less, then less 250 RPM etc until you have 8 values. Then divide total by 8. Basically you have a 2000 RPM window where you average power.
Originally posted by dvallis View PostWent for my first drive yesterday in the newly dyno-tuned car. Wow! What a difference. With our previous "butt tuning" the engine ran strong but felt rough. Now it's super smooth.No hesitation at any RPM and the power comes on like a freight train. When you hit 4500 RPM it slams you back into into the seat like a punch in the chest from Mike Tyson. Had a long time BMW shop owner friend in the passenger seat and he was grinning like a maniac. I was fascinated by the change in boost behavior. With open loop the turbo seemed to meander its way to max boost. With closed loop control the boost gauge instantly snaps to target boost once you get around 4500 RPM.
So, we may get a reprieve on the clutch. From way back when in the build, it's a 6 puck ceramic Clutch Masters FX400 which should have plenty of holding force for the power we're making.
We didn't break in the clutch. #facepalm
Will change out the turbine housing, drive it "normally" at 10 psi (cough, wife laughs) with no WOT for 500 city miles, then report back.Last edited by dvallis; 02-13-2020, 10:19 AM."And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
2002 E39 M5
