m20b20 head on an eta?
  • wolverine_sr24
    • Nov 2015
    • 68
    my car is a 1986 325e 2.7 eta..
    so if i'm correct, the M20B20 is a 731 head correct? which means it'll fit on the M20B27 motor right?
    the dude claims its a real euro motor that came out of a touring, hes going to take pics of the casting number and will let me know.
    My questions: will it be a straight swap? will it produce a significant amount of HP?
    My co worker said that on the pre 88 etas cant straight swap a 885 i head and that the 731 is my best answer. is that true? I will be stroking this car in the long run, but if I have the opportunity to get the head right now I mind as well just do it.
    THANK YOU!
    |OO=[||][||]=OO|
    /____ALPINA____\
    300lbs Deadlift
    1987 325es 2.7i chipped
    1992 325i : SOLD
    2004 e46 M3
    2007 e90 M3
  • digger
    • Nov 2005
    • 6194
    It's a straight swap, should add some horsepowers but it's Impossible to make something worse than an eta so....
    Reality is in stock format that 731 isn't miles ahead of the eta head so don't be expecting 200hp
    • wolverine_sr24
      • Nov 2015
      • 68
      I know for a fact I cant get 200 hp unless I do a turbo on a m20.. I heard that a 731 is a great upgrade for the eta. so i just plan to do that until i figure out what i really want to do with my eta. im leaning towards a 2.7i stroker. I seen a forum on here about a 2.9i which im going to try to achieve :D
      thanks digger
      |OO=[||][||]=OO|
      /____ALPINA____\
      300lbs Deadlift
      1992 325i : SOLD
      2004 e46 M3
      2007 e90 M3
      • jeffnhiscars
        • Jun 2011
        • 6011
        731 came off a b23. I'm not so sure about the b20 but I'm doubtful. Bed check the casting number
        Alice the Time Capsule
        • Hooffenstein HD
          • Nov 2012
          • 1388
          B20 had 731. Late model (motronic) B20 even have dual valve springs.
          • wolverine_sr24
            • Nov 2015
            • 68
            he said its a touring, so im guessing its a late model? is there any difference from having single or double valve springs?
            |OO=[||][||]=OO|
            /____ALPINA____\
            300lbs Deadlift
            1992 325i : SOLD
            2004 e46 M3
            2007 e90 M3
            • wolverine_sr24
              • Nov 2015
              • 68
              so, my co worker said the m20b20 wont work because the bores are to small and that it has to be an b23. can anyone confirm or disagree with that?
              |OO=[||][||]=OO|
              /____ALPINA____\
              300lbs Deadlift
              1992 325i : SOLD
              2004 e46 M3
              2007 e90 M3
              • digger
                • Nov 2005
                • 6194
                youre just using the b20 head right? not the block or pistons?
                • wolverine_sr24
                  • Nov 2015
                  • 68
                  correct, just right now im only using the head..
                  later on next year ill be stroking it with pistons, rods, blah blah blah
                  so will it work?
                  |OO=[||][||]=OO|
                  /____ALPINA____\
                  300lbs Deadlift
                  1992 325i : SOLD
                  2004 e46 M3
                  2007 e90 M3
                  • digger
                    • Nov 2005
                    • 6194
                    you dont want to use the b20 block or pistons for anything, use the b27 block in the car.
                    when you say stroking what crank, rods and pistons?
                    • wolverine_sr24
                      • Nov 2015
                      • 68
                      so yes with the head?
                      maybe the b 25 rods and pistons I saw a thread where a guy was comparing the b23 and b25 cam and supposedly there is no difference. however I havent put that into thought yet, maybe the 545ti? i have to see what goes best and is compatible with the 2.7 build , and I saw your m20b31 build (beautiful<3) and i might go with custom pistons, unsure yet.
                      |OO=[||][||]=OO|
                      /____ALPINA____\
                      300lbs Deadlift
                      1992 325i : SOLD
                      2004 e46 M3
                      2007 e90 M3
                      • digger
                        • Nov 2005
                        • 6194
                        the head is fine to use, it works on both 80 and 84mm bores
                        the b20 pistons/block are 80mm so you would not want them. some people in the UK bore them to 84mm but i personally would just use a b25/b27 block.
                        only thing you don't do is use b25 style pistons and the 200 or 731 head it causes interference
                        • Kershaw
                          • 11822
                          No, you can get 300whp out of an m20 naturally aspirated. Just not very streetable.
                          AWD > RWD
                          • wolverine_sr24
                            • Nov 2015
                            • 68
                            I found an I head for 100, so I think Im just going to swap my head for an 885!
                            |OO=[||][||]=OO|
                            /____ALPINA____\
                            300lbs Deadlift
                            1992 325i : SOLD
                            2004 e46 M3
                            2007 e90 M3
                            • wolverine_sr24
                              • Nov 2015
                              • 68
                              thats if you go full custom work on everything right? I seen some people's build and they are INSANE. where they mod the injectors to shoot to the ports and polishing heads, going super crazy. and they are barely getting up to 230s
                              |OO=[||][||]=OO|
                              /____ALPINA____\
                              300lbs Deadlift
                              1992 325i : SOLD
                              2004 e46 M3
                              2007 e90 M3
