E30 M20B20 and M20B25 engine differences
  • e30austin
    • 15382
    Getting ready to tear into a big project and wanted to clear some things up before hand.
    I have a customer with an '87 325is that was S52 powered that I'm putting back to stock. I have an M20B25 long block (bare) and a complete '88 M20B20/5-speed out of a touring that is getting aforementioned S52. I need to know what I can and cannot use off the B20 to make the B25 a complete engine.
    I know the cooling system (water pump, radiator and the three hoses on the front of the engine) is different, as well as the intake manifold (smaller ports). I know all the accessories (starter, p/s pump, alternator, etc), valve cover, oil pan, etc are the same. I'm not sure if the wiring harness is the same - I have both '88 B20 and '88 B25 engine harnesses at my disposal, but would like to use everything off the known good, running engine.
    I guess my question is: "What can I take off the B20 and install on the B25 to make it a complete engine?"
    Thank you!
  • packratbimmer
    • Dec 2009
    • 1335
    Not much of anything unfortunately.
    • e30austin
      • 15382
      Thanks for the reply, but I'm well aware of the internal differences. I need to know what I can use as far as accessories, exhaust, wiring, etc and other bolt on external parts...
      • digger
        • Nov 2005
        • 6192
        according to realoem harness are same p/n. seem to recall should use b25 ecu as the chip is different
        • e30austin
          • 15382
          Thanks!
          • Hooffenstein HD
            • Nov 2012
            • 1388
            Water pump and hoses should be the same unless it has one of the small non ac radiators. If that's the case, I believe the top hose is the one to use with an M42 radiator.
            Or does it have an early cooling system on it with twin outlet water pump?
            • jeffnhiscars
              • Jun 2011
              • 6011
              I would think the b20 has motronic 1.0 which means an ecu swap would require a matching harness. Of course if the 2 harnesses are truly the same this won't apply but it's something I'd check when you are dealing with swapped cars.
              Alice the Time Capsule
              • e30austin
                • 15382
                It was a small one core baby radiator. The hoses and stuff all look much different than a B25 car. I've got a late radiator I'll use, so no big issue there. It came from an '88, so it had the late water pump.
                • cory58
                  • 1021
                  Radiator went bad on my 88 320i Touring w/AC. Local Bimmer shop replaced it with US-spec radiator, which was larger. They had to remove a blanking plate to fit the larger radiator, but only one hose had to be changed (upper radiator hose). Other hoses were reused.
                  FWIW - I can confirm that the AFM was different on my b20. Not sure what's different, but it does have a different part #.
                  I'm also interested in this thread, since I may decide to swap the b20 for a b25. Would be a huge plus if the wiring harness is the same.
                  Cory
                  1992 325i Cabrio
                  1988 320i Touring
                  2000 M5
                  1977 530i
                  2015 328i - Euro Delivery/Performance Center Delivery
                  BMWCCA
                  E30CCA
