21lb injectors excessive on otherwise stock M20?
  • blitzkrieg59
    • Oct 2004
    • 88
    I picked up an '89 325i at the end of October and the PO told me the M20 was stock outside of 21lb injectors, a Dinan chip, and a cone filter.
    I haven't found any information that supports a notion of the Dinan chip requiring/working better with 21lb injectors.
    Seems to me that these injectors might be a bit too hefty for an otherwise stock M20. The car does seem to run rich. But I'm not sure that's the result of the injectors or a whacked out sensor somewhere. Would there be any advantage to swapping the 21lb injectors out for 19lb injectors or should I just leave well enough alone?
    "Have no small wrecks. If you are going to loop out and hit something, hit it hard." — H.S.T
  • ButtJuice
    • Dec 2009
    • 2609
    M50 injectors, (17.5 lbs?) would be the highest I'd go for what you have.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
    • blitzkrieg59
      • Oct 2004
      • 88
      Thanks for the suggestion.
      • digger
        • Nov 2005
        • 6171
        you need to find out what the chip was "designed" to use. then install those and reset adaptions (leave the battery unlugged for about 30min).
        or get a good chip for SQUID and install relevant injectors to suit as the Dinan stuff will be Meh
        • squidmaster
          • Aug 2011
          • 2666
          Doing injectors that big without a tune for that flow rate would cause some issues. No reason to go that large on a stock setup anyhow.
          • blitzkrieg59
            • Oct 2004
            • 88
            I'm leaning toward replacing the Dinan chip with one of your units, Squid. Would it be foolish to hit you up for a chip tuned for 91 octane and 21lb injectors considering I don't see a cam, MAF conversion, or stroker build in the car's near future? I'd like to solve my rich running condition/poor mileage issue and it'd be nice if I could do it without spending the extra dough for rebuilt M50 injectors — budgets suck. But I don't want to half-ass my daily driver either.
              • 34844
              if the injectors are in good shape, it won't hurt to have a chip made for them. the Dinan tune isn't worth much anyway. I'd go for the SSSquid chip.
              The only real downside is the injector PW will be smaller at lower loads. it's probably not that big of a difference in this case but sometimes you can run into control issues where the commanded injector time is equal to or less than the injector response time. That would really only apply on an injector that is much larger than required (or one with a relatively poor response time).
              • squidmaster
                • Aug 2011
                • 2666
                People with 100% stock cars get chips from me all the time, so don't worry you're good to go. There are always gains to be made.
                Which is why you gotta tune the injector dead time as well for larger injectors ;)
                • digger
                  • Nov 2005
                  • 6171
                  and how do you know what that is without the specific injector to measure? all 21lb arent created equally
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    I would think you map to spec to sell chips off the shelf. Beyond that you find a dyno and dial it in.
                    Alice the Time Capsule
                    • squidmaster
                      • Aug 2011
                      • 2666
                      all 14.5 aren't created equally either, but the factory mapping has dead times for those-- there wasn't a tuner sitting in each e30 as it came off the assembly line to change settings for each car. You can't create a perfect map for every since injector ever made, but you can mitigate the dead time issue to a degree. Since the 21lb injectors that people use are pretty much all the pink tops, I developed a pretty good base map for those injectors.
                      And you're talking about a 1-2% difference between each produced injector, if that. So, in the end, it's not much of a difference.
                      exactly! :)
                      though for injector dead times you don't really need a dyno. You start out tuning the dead times at idle
                      • Advrider639
                        • Oct 2015
                        • 26
                        This might be a stupid question, but I am new to this. Specifically for you Squid, just looking at a 325i chip from you set up with stage 1 and 19lb injectors does it matter if my car is an automatic and I might potentially covert it to manual down the road? Would I have to get a entirely new map?
                        Only reason I ask is that I didn't see anything on your web page that asked either or, but the chips that Turner sells it does ask you to specify what gear box you have.
                        Thanks.
                        • digger
                          • Nov 2005
                          • 6171
                          exactly! :)
                          I take your point about it being small error but i wasn't meaning variations between the same p/n injectors rom manufacturing variations. when you get a 24lb injector for example there are often several different p/n some plastic body some metal body etc etc I've always wondered in the characteristics are different enough to matter
                          • squidmaster
                            • Aug 2011
                            • 2666
                            It mostly depends on metal body vs plastic body. The newer styles tend to be a bit quicker than the clunky ol' metal ones. I find it's always beneficial to ask my customers which injectors they're using, and many customers just shoot me over the part number (ebay sells "24lb" injectors that, according to their spec sheet, actually flow 22.5lb.... so....)
                            • squidmaster
                              • Aug 2011
                              • 2666
                              Thanks.
                              I try to make the tunes as universal as possible, so they have automatic programming in them as well, so you can use it in either a manual or auto.
