Strange piston damage
  • CrazyPrime
    • Jun 2014
    • 286
    What would cause this piston damage and would it require replacement? It was in a m20b25 with 150xxx miles.
    Head is similar but not as bad.
    Sent from my E6653 using Tapatalk
  • Coupelx
    • Oct 2013
    • 169
    Id say it ate something at some point in its life. as long as it didnt pinch the ring groove you could run it.
    • jeffnhiscars
      • Jun 2011
      • 6011
      Perhaps a broken spark plug tip bouncing around
      Alice the Time Capsule
      • CrazyPrime
        • Jun 2014
        • 286
        Ring seats are perfect damage is localized to that one area on piston and head.
        • digger
          • Nov 2005
          • 6176
          Need to smooth the edge looks like it's being dinged up and sticking out the side
          • AndrewBird
            The Mad Scientist
            • 11898
            Considering how plentiful used, good condition M20 piston are, I would just pick up a used one and not run that one.
            • mr2peak
              • 2388
              How's the block?
              Drive it hard. Maintain it well.
              A Topless Memorandum
              • CrazyPrime
                • Jun 2014
                • 286
                Block has zero damage.
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5274
                  looks like it ate something and it got squished into the head/piston at TDC
                  Originally posted by priapism
                  Originally posted by shameson
