Blown head gasket??white smoke
  • e30wavee
    • Jun 2012
    • 36
    1992 325i, white smoke coming from the tailpipe! the car has been sitting since 2008.i just purchased the vehicle don't know much of the history of the car other then it's a 1 owner with 86k on clock plus title & odometer still works barn find pretty much. I check the most commen stuff to look at there's no mixture with the coolant & oil nor oil in the coolant,I let it run for awhile no overheating & heat works great checked around Between the block and the head bone dry coolant doesn't seem to get low the plugs look good not sure about cracked head or block. im thinking maybe Condensation in the interior of the exhaust some say could be a intake manifold gasket or maybe even the rear seal of the brake master,I would really appreciate if anyone could pitch any ideas need to figure this out soon
  • 5Toes
    • 9836
    was the car idling only or what? Take it out on the highway and really rip it around the block, making sure to watch the temp gauge. I doubt the head gasket is blown considering the cars condition...
    probably just a ton of moisture you're seeing as the white smoke. like I said give the exhaust a chance to truly warm up and then report back. it won't happen if the car is just idling
    • e30wavee
      • Jun 2012
      • 36
      I had it run at idle for about 30 45 minutes went around the block a few times at operating temperature still continued to smoke,I was thinking it could be Moisture too I'm still not convinced it the head gasket either
      • 5Toes
        • 9836
        the car has been sitting for ages, you never know. if the coolant is not mixing with the oil or vice versa then you are probably fine. drive it like you stole it and report back. its also cold this time of the year, and some cars (e34s come to mind) smoke like this for whats seems like forever in the winter
        • Kershaw
          • 11822
          Change the oil before you rip it around some back roads.
          But definitely drive it hard and see if it clears up.
          AWD > RWD
          • aegul44
            • Apr 2015
            • 396
            How heavy is the smoke? Does it smoke all the time or only in hard acceleration ?
            If you want to test your headgasket buy this product, cheap and efficient >> THIS
            Esquire E30 Build (87 325i Vert)
            Ultimate Tanning Machine
            • turbo55
              • Jul 2014
              • 223
              Also if you don't know when the timing belt was done, do it!
              • IceWhite
                • Jan 2015
                • 945
                The car has been sitting since 2008, and you want to rip/drive it hard around the block/back roads... I think the Timing Belt should be changed first.
                1990 325i
                2004 330i Individual 6-speed
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I'm surprised this wasn't the first message posted. Running this engine at all is folly until the TB is replaced along with the WYAIT items and all fluids.
                  Alice the Time Capsule
                  • e30wavee
                    • Jun 2012
                    • 36
                    Yeah I know definitely changing the timing belt & fluids as soon as possible just gotta sort this situation out.so I went to start the car this morning still smokes all the time non stop if I rev it smokes even more took nice 15 minute cruise the engine sounds heathy, I don't understand the head gasket on these e30"s are usually bulletproof & since the car still has low miles I just don't consider it being blow but you never know Jst don't want to rip the head apart yet if it's not gasket
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      Take a video and let us see how much smoke is actually coming out. If the exhaust is fully warmed up then there is not much of a way water can enter the engine except for blown head or leaky HG.
                      • e30wavee
                        • Jun 2012
                        • 36
                        sorry about video quality i recorded with my iphone 6 but for some reason youtube makes it look crummy, check out the link and let me know what you guys think
                        • Kershaw
                          • 11822
                          Because it would suck to change the timing belt only to have a cracked head/blown head gasket and have to redo it.
                          AWD > RWD
                          • dnguyen1963
                            • Nov 2011
                            • 2649
                            https://www.youtube.com/watch?v=x5wwARmYyYw
                            My vote is for HG.
                            • e30wavee
                              • Jun 2012
                              • 36
                              Hopefully it's not,Little bit more of investigation & maybe I could find a source. Im thinking its carbon build up burning off still has old gas in it also. The smoke fumes that comes from the tailpipe doesn't smell sweet it smell more like gas only.
