Blown head gasket??white smoke
  • ForcedFirebird
    • Feb 2007
    • 8300
    Pump all the fuel out, start fresh after changing the filter. Also change the soft lines under the hood and around the filter. A car sitting that long is going to be all dried out.
    Also, as mentioned, change the belt, immediately.
    Originally posted by Kershaw
    Because it would suck to change the timing belt only to have a cracked head/blown head gasket and have to redo it.
    I would rather do a timing belt job again vs buying all new valves, rockers and maybe even a head casting if the belt did in fact break in the mean time.
    john@m20guru.com
    Links:
    • jeffnhiscars
      • Jun 2011
      • 6011
      What would suck more would be to have a salvageable head that you grenade cause you are cruising around trying to diagnose a car that you know is a ticking time bomb.
      On the one hand, you waste a timing belt and a few hours..on the other hand you swap an engine.
      Note....is there an echo in here lol
      Alice the Time Capsule
      • aegul44
        • Apr 2015
        • 396
        OP assuming you are Turkish. Yerinde olsam test ederim. Gonderdigim link deki seyi al. Kesin emin olmak icin.
        Esquire E30 Build (87 325i Vert)
        Ultimate Tanning Machine
        • itsonlygeorge
          • Feb 2014
          • 852
          Do the timing belt and water pump before anything else, especially driving like you stole it.
          1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
          Originally posted by nando
          I don't think there's really strong evidence that ZDDP harms cats.
