m20 adjustable cam gear
  • abit
    • Jul 2011
    • 423
    Hi, trying to find adjustable camshaft pulley for m20 engine.
    at the moment could find only one style pulleys on e-bay, maybe someone used them, and could say something about them, or give some other advice?
    other variant of course is ppf pulley, just maybe there is something cheaper but the same quality.
    http://www.ebay.co.uk/itm/2PCS-CAM-G...cAAOSwAKxWbSGJ
    http://instagram.com/mundieriss
    my 88' m20b30 HERE!
  • Kershaw
    • 11822
    I doubt you're going to find cheaper than ebay Chinese made, but for quality...
    The Classic BMW engine builder since 2011. Engines, cylinder heads, parts, and select vehicle work — built by enthusiasts, trusted by builders.
    AWD > RWD
    • abit
      • Jul 2011
      • 423
      that nuke product is what I mean about PPF pulley, I want something like that, but bit cheaper, Chinese pulley is not my goal at all.
      my 88' m20b30 HERE!
      • SkiFree
        • Jun 2011
        • 2766
        I used to sell the ebay pulley and while they would work in a pinch the teeth were just far enough off that it would stretch the belt abnormally (I did see a couple cases of rapid timing belt wear associated with this issue).
        Took these pictures to illustrate the problem ....
        No, there is no "cheaper" alternative that is worth anything at this point. The guys at VAC do one, but they just machine out an existing gear and put their own innards in it (and the pricing is a hair bit more).
        ADAMS Autosport
          • 34847
          yeah, that ebay gear isn't bad quality but the belt teeth aren't quite right. it makes installing the belt a giant pain in the ass.
          • abit
            • Jul 2011
            • 423
            ok, thanks for participating in the debate, I ordered nuke gear :)
            my 88' m20b30 HERE!
              • 37834
              http://www.bimmerheads.com/catalog/m...camshaft-gear/
              Grover Beach, California
              BimmerHeads.com
              • whodwho
                • Jun 2008
                • 1547
                Was there an issue with the Nuke ones at one time?
                The belt fits that way on my Nuke one as well, I was surprised at the fit. I didn't know if it fit that way on a new OEM one and wears in over time.
                I took some pic of all three as well a while back, I will see if I can find them.
                My M20 Frankenbuild(s)
                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • 34847
                  I don't see how a rubber belt could wear a steel gear.
                  • SkiFree
                    • Jun 2011
                    • 2766
                    ^ Nando, you've got it backwards (as I'm guessing you were guessing).
                    Yes, but it was something they nipped in the butt pretty quick.
                    ADAMS Autosport
                    • whodwho
                      • Jun 2008
                      • 1547
                      Same as a rubber crank seal wears a groove into the crank
                      Bummer, I guess not quick enough for me 8^(
                      So they originally designed it up from an ebay one and not an OEM?!?! 8^)
                      • digger
                        • Nov 2005
                        • 6215
                        i have a new Nuke and OEM here in front of me, the contibelt wraps around the OEM slighty better than it does on the Nuke which needs a little bit of tension to get it to fully mate.
                        The blue gates fits OEM well but on the Nuke it would need even more tension than the conti to fully mate but not near as bad as the IE bottom pic.
                        if you compare teeth they are slighty different shape (depth) on the Nuke vs OEM gear. in a way it makes sense for the belt to fit best under a bit of tension as that's how it operates.
                        ive been using a nuke for 8 years and done a few belt swaps without issues and will be using another for new engine. the biggest hassle was having to pull the hex bolts for the cam seal carrier (one at a time) and countersink the carrier to fit countersunk screws but dont know if this is still the case.
                        • SkiFree
                          • Jun 2011
                          • 2766
                          Email me when you can Keith. The guy who heads up NukeNA is a pretty understanding.
                          ADAMS Autosport
                          • whodwho
                            • Jun 2008
                            • 1547
                            Perfect, thank you
                            • digger
                              • Nov 2005
                              • 6215
                              out of curiosity when are we talking? they have been around for ages
