M20 main bearing studs?
  • slow325isedan
    • Mar 2013
    • 113
    So arp doesn't make main studs for the m20? That seems weird lol, well I need to stud my crank so what are my options? Will studs from another engine work? Need help! Lol thanks guys
    Build Thread
  • TobyB
    • 5287
    No help, but I've never heard of the main journals being particularly overstressed.
    Rods, yes...
    t
    • digger
      • Nov 2005
      • 6194
      yes ARP do make a main stud set that fits. you will likely need a line hone though if you change the preload.
      when i get home ill check the code on the box as it may be the same as one of the other engines. there is a guy who used to sell them on here
      • whodwho
        • Jun 2008
        • 1547
        Same as M5x, should be ARP 201-5000
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • slow325isedan
          • Mar 2013
          • 113
          The engine is being fully built so it is getting line honed, shooting for 6-700hp when done so want to stud the crank lol, if you could check on that part number that would be awesome! And I'll cross reference that part number, thanks guys
          Build Thread
          • digger
            • Nov 2005
            • 6194
            the m20 main bolts are the same P/N as the m50 ones in real oem so whodwho will be right
            • nomansland92
              • 1657
              Arp does have mains and rod studs for m20, check Ireland engineering that's where I got mine
              IX being restored here
              Ix turbo build here
