Age old Question/Argument
  • Tex_E30
    • Jan 2016
    • 77
    SO the question is....
    Who uses what oil Brand and Viscosity?
    Seems to be a lot of Im right your wrong regarding something so simple.
    90 325i TrackRat uncaged
    89 ZinnoRed Riot 325is
    13 Cognito PPEI Duramax
  • dnguyen1963
    • Nov 2011
    • 2651
    Why do you bring an old and beaten topic back from its death?
    • digger
      • Nov 2005
      • 6215
      10w-50 summer up to 43c ambient oil temp up to 105c
      10w-40 winter down to 0c ambient oil temp up to 85c
      Gives good pressures, could use a better viscosity for cold weather 10w-40 still a bit thick on cold mornings
      Problem with oil companies they dont give data at 0c normally only 40c and 100c
      The viscosity you need is strongly dependent on the oil temps
      • packratbimmer
        • Dec 2009
        • 1335
        Mobile One bad
        Castrol good
        • shoshottz
          • Jun 2016
          • 128
          [emoji1540][emoji1540] justify your statement sirpackrat!?
          shottz.
          • packratbimmer
            • Dec 2009
            • 1335
            34 years of experience
            All of the Castrol engines have stayed clean and not worn out
            Mobil One engines turn black or worse, foul up lifters...trash
            • noid
              • 1537
              15w40 rotella T diesel oil
              Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
              Your resource to tools and tips: www.rtstools.com
              • packratbimmer
                • Dec 2009
                • 1335
                MMMM - zinc and phosphorus
                • supermansocks95
                  • Feb 2016
                  • 756
                  +1 on the Castrol
                  20w50 synth blend(working up to full) in the summers
                  rotella 15w40 in the winters
                  88 325i Cabrio
                  04 Neon SRT-4
                  If R3v was a dude, it would pick up a tinder date naked, with a raging boner, drunk, in an e30 with a shitty interior, a missing sunroof panel, explaining how its a classic while staring at the tinder date's tits.
                  • shoshottz
                    • Jun 2016
                    • 128
                    hmmm...
                    well i live in TEXAS & its literally 104 right now ive been using mobil 1 10w30...and was thinking about upgrading to the extended performance, any idea on which castrol full synthetic would be the equivalent to mobil 1? edge? @packratbimmer
                    shottz.
                    • shoshottz
                      • Jun 2016
                      • 128
                      thanks for the insight btw.
                      shottz.
                      • packratbimmer
                        • Dec 2009
                        • 1335
                        Depends on how much money you want to spend. The most important consideration is that there are enough additives in the oil to protect your cam/rockers.
                        I used the following study before switching to Cummins/Valvoline Premium Blue 15w 40 purchased at tractor Supply for $15 a jug (its just one gallon though):
                        http://www.turbodieselregister.com/TDR57_Oil.pdf
                        So far so good as far as I can see, but I am not sure what I will switch to for the cold long Maine winter. A couple of years ago, it barely got above freezing the entire month of February.
                        From what I have read (and I am not an expert), the catalytic converter construction and placement will allow use of oil with higher additive levels such as diesel oil.
                        Good news for you is that the winter oil issue should not be an issue.
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5288
                          M20?
                          Castrol GTX
                          10w40 winter
                          20w50 summer
                          refer to your manual for what ambient temp/oil
                          Turbo, sure go synthetic. Otherwise, waste your money at your own discretion.
                          Originally posted by priapism
                          Originally posted by shameson
                          • packratbimmer
                            • Dec 2009
                            • 1335
                            I have always been a fan of Castrol GTX as well but there is a little controversy over the zddp content on the newer formulas (amazing experience with Castrol GT back in the day too).
                            Just to be safe, I would consider an additive for the M20 if I used GTX.
                            • digger
                              • Nov 2005
                              • 6215
                              why not buy an oil that doesnt need an additive?
