smoke screen out the tailpipe
  • Morky
    • Jun 2016
    • 41
    So i noticed a wierd thing with my car today. Upon startup a good amount of white smoke comes out of the exhaust up until the engine warms up, then the smoke comes out in small bursts no matter the outside temperature. If i drive the car around and then let it idle however, no smoke persists out the exhaust, the problem only exists upon start. Should this be something to worry about? my car is a 90' 325i
    If you're not first you're last :nice:
    1987 325is
  • packratbimmer
    • Dec 2009
    • 1335
    Blue smoke on startup and deceleration (like an exit ramp or long hill) is valve guide seals. White steam could be just condensation in the exhaust and hopefully not a cracked block/head or failing head gasket. Keep an eye on the coolant!
    • TobyB
      • 5298
      The M20 puts out a prodigious amount of moisture when it's warming up....
      t
      • packratbimmer
        • Dec 2009
        • 1335
        Yea - do you live in a humid place?
        • jeffnhiscars
          • Jun 2011
          • 6011
          He's in the rainforest north of Vancouver (best skiing anywhere). When I lived in BC you'd get white smoke on start up just from the ambient humidity and cool exhaust
          Alice the Time Capsule
          • packratbimmer
            • Dec 2009
            • 1335
            That explains it...
            • Morky
              • Jun 2016
              • 41
              I noticed that there's a lot of water that comes out as well. I live in Whistler BC so that definately explains it
              1987 325is
              • jeffnhiscars
                • Jun 2011
                • 6011
                If you drive short trips so the engine doesn't get good and warm condensation can accumulate in the exhaust. Standing moisture and h2so4 = very short lifespan of your pipes.
                Try to ge t out on the Sea to Sky for a good romp as often as you can.
                • Morky
                  • Jun 2016
                  • 41
                  will do hommie (y)
                  1987 325is
