Engine Harness and Wiring question
  • ivprodigy
    • Feb 2014
    • 33
    My track car project has been stalled for some time now.
    I'm thinking of going back to a stock M20 engine, just to get the car moving (while possibly doing a proper m20 rebuild).
    The car's interior wiring is pretty gutted but I have an engine harnesses and stock ecu that are unmolested.
    What is the minimum wiring/switches/relays that I need to have connected via the C101 to the engine harness for the engine to fire and run (not worried about emissions)?
    working progress...
  • ivprodigy
    • Feb 2014
    • 33
    Bump. Anyone have any insight?
    working progress...
    • TobyB
      • 5298
      Not much. I'd start with a wiring diagram, and go from there.
      t
      • varg
        Florida Turbo Man
        • May 2014
        • 3439
        Everything? The only "emissions equipment" on your car should be the evap solenoid and that doesn't go through C101. You can go without the oil and coolant level sensors which do go through C101.
        IG @turbovarg
        '91 318is, M20 turbo
        • TobyB
          • 5298
          There aren't that many pins on c101- maybe 12 or so are populated?
          t
