Better Fix for Thermostat Housing Leaks?
  • Aleman
    • Mar 2012
    • 1609
    The thermostat housing is made of aluminum which bends and gouges easily. It can get damaged, and that commonly results in coolant leaks.
    Most people say to put a bead of RTV on the surface of the housing cover where it contacts the base, then button it up at the proper torque spec. This works for a while, but it's messy to clean up when you have to open it up again to change the thermostat down the road.
    Has anyone had success cutting a paper gasket for the therm housing? I would expect that to be a better solution.
    If that works, then I wonder why the hell BMW didn't take that approach from the get go?
    Thanks!
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
  • digger
    • Nov 2005
    • 6199
    which part leaks? there is an o-ring there, pretty sure it is the part that seals. you can buy new parts they arent very expensive for what it is
    • Aleman
      • Mar 2012
      • 1609
      I have a new o-ring, but the housing is leaking like a sieve. I think when I was scraping off the PO's RTV I scarred the housing cover-to-base surface. If the rubber o-ring really is the only seal that's needed, I'll take a closer look at the lip where it sits inside the base. Maybe some debris fell in there.
      ....or I'll go and cut me a paper gasket LOL
      ..24
      • digger
        • Nov 2005
        • 6199
        paper gaskets can work but id use some aviation cement non hardening type and have metal on metal. give the faces a quick linish first off
        • e30davie
          • Apr 2016
          • 1788
          Its just an o-ring that seals according to the schematics
          Both surfaces where the o-ring sits need to be perfectly clean.
          Unless you are talking about part #4 in that link, which is the gasket from the thermostat housing to the head.
          • jeffnhiscars
            • Jun 2011
            • 6011
            I spent a lot of time on this leak until I realized I had crimped the o ring so it wasn't seated properly. $2 later it's been fine.
            Alice the Time Capsule
            • TobyB
              • 5296
              Paper gaskets don't work so well on coolant- it wicks its way down the
              paper, eventually softening to mush. Meanwhile, the aluminum starts to corrode.
              Nissan did it that way a long while back. It sucked getting old parts engines apart...
              t
              • digger
                • Nov 2005
                • 6199
                the one on the back of the head and to the head is made of cardboard type stuff, buy a sheet of stuff from ebay and make your own. personally id be chasing the root cause and fixing that
                • cscracker
                  • Jan 2017
                  • 131
                  Yeah, the O-ring does all the sealing, no paper gasket or RTV necessary. If yours won't seal it must be in pretty bad shape. A new housing isn't too expensive (~$40-50 for both the housing and the cover) and chances are, your leaky one is also super crusty everywhere else.
                  Housing
                  11531730470
                  https://www.ecstuning.com/b-mtc-part...531730470~mtc/
                  Cover
                  11531265059
                  https://www.ecstuning.com/b-uro-part...531265059~uro/
                  Against the block, that side does need a gasket. If you replace the housing, you'll need a new one.
                  11531722692
                  https://www.ecstuning.com/b-genuine-...t/11531722692/
                  • digger
                    • Nov 2005
                    • 6199
                    id by the genuine stuff for an extra $50 all up, MTC and URO are the worst brands around
                    • Aleman
                      • Mar 2012
                      • 1609
                      On my vert, I just replaced a bad thermostat and put in a new housing gasket. It leaked pretty bad, but I would say that I probably had some old RTV somewhere on the sealing surface. I went and put RTV on the seal and no more leaks.
                      My other E30 got a new thermostat 5 years ago, and I've put on about 6k miles since then. Coincidentally, that therm housing is now leaking for no reason other than age maybe. I guess I will know more once I open it up. How long should a gasket last? Seems like this could be one of the M20's weak points.
                      Thanks for all the advice so far guys. Good stuff here
                      ..24
