Timing Belt Age
  • jeffnhiscars
    • Jun 2011
    • 6011
    Timing Belt Age
    I was thinking to change my 4.5yo tb before heading to the Vintage, even though I've only put 32k on it. I opened the new sealed Conti Kit and the new belt is date stamped July 2015. Hardly makes sense to make an age based swap.
    My 2c
    Alice the Time Capsule
  • M_3_X
    • Jul 2016
    • 162
    Would be interesting to know what's the "shelf life" of a belt.
    Definitely is not receiving any stress if it's not installed.
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    ___________________
    River City Bimmers BMW CCA
    2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
    2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
    1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
    • jeffnhiscars
      • Jun 2011
      • 6011
      Agreed
      • Swanny
        • Mar 2012
        • 2834
        Its kind of like tires in the sense that the rubber degrades over time. How long it takes to become prone to failure is the real question. Maybe just soak it in 303 since it works so good on the dashes?
        Jkjkjkjkjk
        Swanny!
        SUCKERS.
        • jeffnhiscars
          • Jun 2011
          • 6011
          I'm sure someone will say they got 10 yrs from a belt by doing this. Of course you have to remove it to treat it but hey...a penny saved.
          Jkjkjkjkjk
          • mjposner
            • Aug 2015
            • 169
            Mine was installed 4.5 years ago and has only 4k miles of use...everyone says change.
            • agent
              Vice Grand Pubaa
              • 7960
              I put 7,200 miles on Klaus' last belt in just over 7 years, and it came out looking and feeling brand new. It's in such great shape I have it for sale.
              Originally posted by kronus
              • ahlem
                • 369
                We stripped the teeth off a timing belt within the mileage requirements but outside the freshness date. Broke the head in the process. I would highly suggest changing the belt, way cheaper.....
                • TobyB
                  • 5287
                  ...at varying speeds depending on the conditions it's subjected to...
                  The belt that's sitting in a box in a climate- controlled environment's doing
                  a lot better than one on a car sitting out in the weather, getting run once or
                  twice a week. In the rust that forms on the surfaces of the pulleys because it's raining.
                  I just realized, the belt on the race car is 5 years old. I should change it some day...
                  heh
                  it's all about your comfort level....
                  t
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Considering that there still e30s on the road running the original timing belt, I wouldn't worry a bit. I mean, yeah, those cars are ticking time bombs, but anything under 75k I wouldn't even consider an issue.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      I've now got this...a little too much heat nextnto #5 plus wire so may leave it home anyway
                      • mjposner
                        • Aug 2015
                        • 169
                        My car was in a/c storage until December and now in a regular Florida garage with 4.5 years on the TB. Still only 4k miles. I know there is a risk, but if I were to wait a few months (driving only a few hundred miles) I presume the risk is low. Also, does spirited driving really make the risk worse?
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          As long as it hasn't just sat for 4.5 years I wouldn't lose too much sleep over but I wouldn't get complacent about it either. I'd also say that if a belt gets weak a good punch on the gas pedal,is more likely to push it beyond its limit than driving to church on Sunday
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            They always do that when they fail. I have seen too many failed belts over the years of working on these cars. Worst part is, people would come in and have suspension work etc and they would have the belt snap not long after. I always suggest that if you don't know your belts age, just change it now while you can. Always crack up when they reply "but it runs fine, and the belt looks ok." All the failures looked fine too :/
                            heh
                            t
                            This. Takes a few hours to avoid a whole lot of hours (and $$).
                            john@m20guru.com
                            Links:
                            • zaq123
                              • Jul 2016
                              • 1560
                              7 years is max life for any TB out there.
                              BMW recommends 4 years max,Bulletin Number 11 18 85 (1097).
                              After that.....you can join AndrewBird and start thinking that your car is a time bomb.
