Oil Pump
  • E30arsen
    • Sep 2016
    • 135
    Oil Pump
    I'm in the middle of doing a 3.0 strokeron my m20 and I was wondering, is it worth spending $330 for a bmw oil pump, just go for a Febi oil pump which is $200, or reuse my oil pump?
  • Blach178
    • Jan 2017
    • 5
    Get a 324td, Oilpump when your at it :) delivers better pressure.
    Don't hang with your head, if you stand in a pile of shit :neutral:
    • zaq123
      • Jul 2016
      • 1560
      interesting... is it really? I just ordered new M20 pump. should I cancel the order and order 324td? Is it really worth the upgrade?
      To OP....if you are rebuilding your motor, new pump is definitely worth $300.
      • redlightpete
        • Mar 2012
        • 266
        That td pump was likely sized to supply oil to the turbo. It might just be a waste of power on a N/A motor. Has anyone had problems with oil pressure/volume with an m20 (that wasn't caused by a lack of oil supply to the pump)?
        • digger
          • Nov 2005
          • 6198
          would probably want a restrictor in the sprayer bar to stop the oil pooling into the head at high rpm
          • E30arsen
            • Sep 2016
            • 135
            I was just curious it was worth going OEM or aftermarket.
            • ForcedFirebird
              • Feb 2007
              • 8300
              The b25 oil pump has plenty of volume, and if you cap the pressure relief valve, they have 90psi cold and 70psi hot pressures. A couple of my racing buddies deleted their relief and no issues with pooling oil.
              john@m20guru.com
              Links:
              • digger
                • Nov 2005
                • 6198
                OE would be what id do if you are doing a decent $$$ build
                • E30arsen
                  • Sep 2016
                  • 135
                  Cool, thanks for the advice.
                  • SkiFree
                    • Jun 2011
                    • 2766
                    The aftermarket may also be the OEM supplier. I know this was a case with Febi for a while. They had come from the same mold, but then stamped with either Febi or BMW markings. Don't think Febi's are available any more?
                    Not sure what the case is now.
                    FYI, I do fully-rebuilt (using all OEM bits [gears/spring/etc.]) pumps. Several pumps running on SpecE30's and stroker builds.
                    ADAMS Autosport
