How much power can a stock transmission take?
  • FireFight
    • Mar 2012
    • 1367
    Hey guys, I'm doing a m60 swap in a car, but trying to get the 5 or 6 speed stuff is becoming a nightmare, I was able to to find this
    It adapts the a m20/m50 transmission to work on a m60.
    I know 92-95 E36 transmissions are ticking time bombs, and e30s had stronger transmissions. anyone know what their limit seems to be?
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • TobyB
    • 5287
    What about a trans out of an E46 330 or M3?
    I forget where, now, but I recall seeing that those-
    especially the 5- speed-
    were rated for a surprising amount of torque.
    And you can find them all day for $200 or so.
    The 260 is (relatively) heavy and weak...
    just what I remember from surfing the webs,
    t
    • FireFight
      • Mar 2012
      • 1367
      Thank I'll look in to that
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      • varg
        Florida Turbo Man
        • May 2014
        • 3425
        It'll take a lot more than a NA M60 will dish out.
        IG @turbovarg
        '91 318is, M20 turbo
        • agent
          Vice Grand Pubaa
          • 7960
          Originally posted by FireFight
          I know late E36 transmissions are ticking time bombs, and e30s had stronger transmissions.
          ZF320s are ticking time bombs? That's news to me. Getrag 260s are stronger? Also news. Where'd that info come from?
          Originally posted by kronus
          • JOMARO
            • Mar 2006
            • 116
            I have M50b30 turbo with 360 lb/ft and my getrag 260 is holding up fine
            intending to raise boost to 500 lb/ft on it too :-)
            • The Dark Side of Will
              • Jun 2010
              • 2796
              The M60 5 speed is the same ZF 320 as used on the 24V engines.
              I don't understand how "trying to get the 5 or 6 speed stuff" is a nightmare, or how ordering a part from Europe that costs more than you should expect a V8 5 speed to cost is in any way preferable.
              • FireFight
                • Mar 2012
                • 1367
                I never said that the ZF320 in peticular was a ticking time bomb, but the Getrag was a weak transmission, and they where ran from 92-95. i have personally swapped out 2 blown getrags from stock e36s in the past 2 years.
                but I have never had a e30 trans take a shit on me after the dozen I have owned. And I dont recall anyone that has told me their trans in a e30 blew up.
                based off that my assumption was that the e30 trans may be stronger when compared to the Getrag in the e36
                (post 4)
                WTB:m60b40 in PNW
                Zachary Ripley
                85 318i M50B25tu.
                92 525it 5 speed.
                • agent
                  Vice Grand Pubaa
                  • 7960
                  That explains part of it. You said "late E36 transmissions are ticking time bombs." 92-95 are early E36; 96-98 - which had the ZF320 - are late E36. That said, I agree with you. I wouldn't use a Getrag out of an E36 for any swap.
                  • FireFight
                    • Mar 2012
                    • 1367
                    Your right, I was thinking e34 in my head, not e36 haha
                    I fixed the OP
                    WTB:m60b40 in PNW
                    Zachary Ripley
                    85 318i M50B25tu.
                    92 525it 5 speed.
                    • agent
                      Vice Grand Pubaa
                      • 7960
                      :up:
                      • FireFight
                        • Mar 2012
                        • 1367
                        Shop for the price of a new m60 flywheel and clutch kit compared to a m50/m20.
                        Flywheel
                        $613.45
                        $334.01
                        compared to a e30 which was the original question
                        clutch kit
                        297.09
                        I already have a flywheel and transmission so $0
                        and adapter
                        http://www.ebay.com/itm/BMW-M60-M62-...53.m1438.l2649
                        $359.99
                        so total would be $657.08 if i can run an E30 transmission
                        compared to 947.46 if I where to run a m60.
                        plus the cost of the transmission, which fetch a decent price because e34 guys want them, supply and demand.
                        WTB:m60b40 in PNW
                        Zachary Ripley
                        85 318i M50B25tu.
                        92 525it 5 speed.
                        • Dgerry
                          • Oct 2016
                          • 54
                          Good info here, I could not find on the listing where it stated the flywheel that you used with the adapter. Are you saying that you could use the stock M20 Flywheel behind the M60? Bolt pattern? Spacing? ON their website they have an adapter for the V12 too, that gives me ideas for the E28....
                          • FireFight
                            • Mar 2012
                            • 1367
                            Im not sure, Austin! and i were talking and he is pretty sure that they are the same bolt pattern, but i cant find any info on that
                            WTB:m60b40 in PNW
                            Zachary Ripley
                            85 318i M50B25tu.
                            92 525it 5 speed.
                            • TobyB
                              • 5287
                              ...the 260s in Pro3 cars are not particularly robust.
                              But:
                              the drivers of Pro3 cars are pretty hard on their transmissions,
                              since in theory the cars are pretty closely matched. So while we're killing
                              them weekly, it doesn't mean they don't hold up when NOT abused.
                              t
