Valve Cover Stud
  • Idrisu
    • Jul 2015
    • 173
    Valve Cover Stud
    When installing new valve cover studs how much should be left out? They're about an inch and a half long.
  • Idrisu
    • Jul 2015
    • 173
    bump
    • 15Michaeljoseph
      • Aug 2013
      • 1693
      Fit the valve cover, and see if they stick out enough to fully tighten it down. I adjusted and readjusted to make the studs flush with the top of the nuts when the nuts are tight
      Sent from my XT1064 using Tapatalk
      (OO=[][]=OO) For Life
      • dnguyen1963
        • Nov 2011
        • 2649
        1.5" long is awfully tall. The valve cover is not that thick. But then again, there is nothing on top of the cover that would interfere with the extra length. It just looks ugly.
        • Das Delfin
          • Sep 2014
          • 2293
          You could do just tall enough to secure the valve cover with a standard nut, then put an acorn nut on top. That way you can have the two that secure the spark plug wire holder held down by hex nuts, the same as the others, but have the spark plug wire holder secured by the acorn nuts. So that if you remove your spark plug wires you don't mess with the tension on your valve cover. Also so there is less stress on the spark plug wire holder
          Does that make sense? It's been a long day
          • digger
            • Nov 2005
            • 6119
            the studs are supposed to be 35mm long so they shouldn't stick out 38mm
            i use the fancy nuts 11121401517 ($$$), had to shorten a few of the studs a little to get it to work from memory looks awesome with a powder coated valve cover
            • Kershaw
              • 11822
              FFS, $9/piece?
              You know you can get acorn nuts at your big box home improvement store for $9 for all of them, right? Lol.
              AWD > RWD
              • digger
                • Nov 2005
                • 6119
                I used to have the acorn ones. The BMW ones look nicer and are better material feels like less made in China.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  I like using stainless set screws. They have a nice hex drive broached in the end. Buy them in the box of 100, but don't remember the price.
                  john@m20guru.com
                  Links:
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    Originally posted by Kershaw
                    FFS, $9/piece?
                    I went that route and found those acorns to be a little short. Rather than cutting anything I used a couple of copper washers from a HF kit. The copper and SS reminds me of the marine engines I've had :)
                    Alice the Time Capsule
                    • Idrisu
                      • Jul 2015
                      • 173
                      After buying OEM studs/bolts and using red loctite it still wouldn't tighten down... The stud would just come loose.. I put half the stud into the head and waited 24 hrs for it to cure. I'm thinking about using these, has anyone tried them?
                      • 15Michaeljoseph
                        • Aug 2013
                        • 1693
                        I wouldn't use them. Something about head thread depth/ thread wear and using screws where a stud once was doesn't sit right with me. If possible, try to find a shorter stud at a hardware store? You're double-nutting the OEM studs to install, correct? I mean, when I put in mine, I actually had to back a few of them off because I screwed them in too far to get the nut on over the valve cover.
