My e30 has no power
  • E30_Andy
    • Mar 2015
    • 10
    My e30 has no power
    Every time I give the car throttle the rpm rises but the car hardly goes. It's automatic and when it goes to high rpm it's gives it kicks the car and shift. If anyone knows what the problem might me please let me know thank you
  • TimeMachinE30
    • Jun 2014
    • 3749
    No power? Swap it!
    To diagnose, can ya say if anything changed? Recent fill up? Just swapped out some parts? Hit a big puddle?
    Can you do a stomp test? What year? What motor?
    ACS S3 Build / Dinan 5 E34
    • 1843lamp
      • Sep 2015
      • 276
      It must be particular to cars in north Hollywood .I bought a replacement car for my tired 87 ,it had 102,000 original miles but it does not accelerate like my old car,I still can not locate the difference ,the old car is original and has three times the miles on it ,very frustrating ....cars from north Hollywood..
      • E30_Andy
        • Mar 2015
        • 10
        Originally posted by TimeMachinE30
        No power? Swap it!
        It's an m20 engine, year is 1988 325i, I've never done a stomp test and I also don't now how to, my last fill up was today I put 89 in there. I might be guessing it is the master air flow so I ordered a new one I'm hoping that is the problem.
        • cheffy30
          • Sep 2016
          • 1159
          you need to run 92 through that m20. start with fact your using crappy gas...
          Sent from my HTC One M9 using Tapatalk
          '90 325i sedan daily driven
          '85 325e coupe also a daily
          • E30_Andy
            • Mar 2015
            • 10
            They have 91 in LA. I've always put 91 in my car, some mechanic told me that it's not good to always put 91 in your car since it is an old car it's not good for your car
            • LowR3V'in
              • 4209
              yeah bro, start with the fact you're using 89.
              insert eye roll emoticon.
              • Todd Black 88
                • Oct 2007
                • 3449
                It's a tractor motor, it can run on 87 and is in fact designed to run on 87.
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                • cheffy30
                  • Sep 2016
                  • 1159
                  The M20B25 can potentially run for a million miles or more with the proper care at the right intervals....
                  We know this though... Regardless.... 90+ octane is a smart move....
                  • cheffy30
                    • Sep 2016
                    • 1159
                    Honestly though i dont think it really matters for simple daily driver habits but if your'e a high-r3ver or you beat on it and you care about your engine then go for the premium. lol
                    • e30davie
                      • Apr 2016
                      • 1788
                      Need more info mate..Has this been the issue since you have owned the car? or did you do something and then after that it started?
                      options and potential things to check based on your descriptiong include,
                      -google stomp test, perform it, let us know results.
                      -Incorrect ignition timing, though thinking again I don't think you can actually change it.
                      -Fuel filter blocked (have you ever changed it?)
                      -Catalytic convertor callapsed or exhaust blocked?
                      -Is the auto playing up? does it have enough fluid?
                      -Is the hand brake or brakes stuck on?
                      -Can you hear the engine ping or detonating?
                      -When was the last time you adjusted the valves?
                      -Is the air filter clogged? (unlikely cause, but possible if VERY bad)
                      -Are you actually getting ignition break down?
                      -Have you ever changed or checked the condition of your spark plugs or distributor cap?
                      -Have you actually done any checks on your mass air flow meter before blindly buying a new one?
                      -What is the fuel economy like? is it running very rich?
                      -Forget the fuel type comments.
                      • uturn
                        • Dec 2010
                        • 1005
                        Unless it's chipped or you had high compression pistons installed you'll be fine on 87 octane.
                        It's an automatic, so first thing is to check transmission fluid. Could be low or burnt, burnt means you're looking for a rebuild or should be planning a 5 spd swap.
                        • E30_Andy
                          • Mar 2015
                          • 10
                          I am planning on doing a 5 speed swap real soon I'm just looking for the right one that comes with all the parts you need for the swap
                          • E30_Andy
                            • Mar 2015
                            • 10
                            I will try the stomp test and I will let you know what codes it's gives me
                            • dnguyen1963
                              • Nov 2011
                              • 2651
                              I have been using 87 in my car for as long as I remember and never had any issue.
