Pistons for m20 Stroker
  • .n0iz4!
    • Nov 2017
    • 12
    #121
    Yea this looks pretty accurate. Would you share your work with me? When you dont want to, no problem.
    My last two problems are that i have to measure the Radius of the "Piston Ball - the convex shape" and the position and Radius of the Concave/Dome Ball.
    I think its x+8 and y-8 but this is too unaccurate for me. Also the Radius at the 9,7 - somthing from 200mm-210mm(Diameter) could be correct but... for me its tooo unaccurate :?
    Some idea is to clamp the piston on the CNC and take a dial indicator and "drive" above the piston. Write down the Points and get the Radius :D
    • digger
      • Nov 2005
      • 6191
      #122
      for the 9.7:1 +0.5mm piston it is, R100 convex (dome) and R107 concave (dish)
      • .n0iz4!
        • Nov 2017
        • 12
        #123
        Thanks alot!
        I'll check this on thuesday/friday at the cnc.
        It is correct that the Offset is x8 y-8 ?
        • digger
          • Nov 2005
          • 6191
          #124
          I had It closer to 7mm but hard to measure. Small variation Doesn't matter much though
          • .n0iz4!
            • Nov 2017
            • 12
            #125
            Didnt had the time for the Piston "measure".
            I'm too busy buildin my own Rocker arms, sorry.
            Will get back to the pistons soon!
            • E30-325iS
              • Sep 2011
              • 191
              #126
              So start a new thread and show us your work on the rocker arms.
              • .n0iz4!
                • Nov 2017
                • 12
                #127
                I already started a new thread in our german e30-talk Forum :D
                Ok, ich bin nicht allein zu Haus, aber nen Motor bau ich trotzdem! Der M20 brauch eine Revision, dazu später mehr.Einzug wird die, mittlerweile „häufig“ verbaute M52B28 Kurbelwelle mit 84mm Hub, 130mm Pleuel aus dem M20B20 und eine scharfe Nockenwelle erhalten. Kein seltener Umbau mehr, aber das ...
                There you can watch it. But its not finished yet. The Problem ist the strength / how much Newtons go into the rocker-arm etc.
                But i'm on the way... maybe :D
                • .n0iz4!
                  • Nov 2017
                  • 12
                  #128
                  Ok, back to the Pistons.
                  Offset Wiseco should be X+5.9 Y-6.05 (~6)
                  Merry Christmas :D
