Pistons for m20 Stroker
  • zaq123
    • Jul 2016
    • 1560
    #91
    Originally posted by 2mAn
    so I just found out who bought the 85mm Mahle pistons I was trying to buy :hitler:
    doesn't IE has more or they are out?
    • ForcedFirebird
      • Feb 2007
      • 8300
      #92
      The s54 has notches in the bottom of the cylinder bores in the block, and notches on the piston skirts to accommodate bob weights. The biggest trick in a short rod:stroke engine is to keep as close cylinder/piston boundary as possible, maximize the piston skirt. Side loads are high and rotational clearances get tighter. TDC dwell has become near non-existent. Now we are talking about stuffing that in the shorter m20 block with more primitive valve train.
      john@m20guru.com
      Links:
      • apostate
        • Feb 2012
        • 148
        #93
        • 2mAn
          Señior Mod
          • 20991
          #94
          Im sure they have more, but the price is different when bought new from IE VS in the r3v classifieds. I just waited too long because I really am nowhere near close to actually building a 2.8L M20
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • digger
            • Nov 2005
            • 6192
            #95
            by my calc
            pin is 22 mm
            throat is 5.5 mm
            rod 133 mm
            CW R70.5 mm
            throw 44.8 mm
            then the clearance is 1.2 mm to the pin boss.
            • bmwmaster81
              • Sep 2012
              • 49
              #96
              Thank you for calculation digger. Seems to be tighter than I expected but schould be enough.
              The squish on oem m20 is also 1.2mm without Problems. I will check if the tolerances are right an when everything appears equal between the different cylinders I think it schould rotate free also unter high rpm.
              Because of the long stroke I also wouldn't rev more than 6500 rpm.
              • digger
                • Nov 2005
                • 6192
                #97
                the calculation is relatively straight forward
                CL = rod length - throw - CW - Pin/2 - throat
                • digger
                  • Nov 2005
                  • 6192
                  #98
                  im using 135mm rod and 46.9mm throw but 20mm pin to fit
                  • apostate
                    • Feb 2012
                    • 148
                    #99
                    • digger
                      • Nov 2005
                      • 6192
                      #100
                      With the rhd intake, good head and appropriate cam you will peak closer to 7000
                      • bmwmaster81
                        • Sep 2012
                        • 49
                        #101
                        I got the pistons today ;D
                        Unfortunetly in the manuel they don't write how much bore clearance the pistons need
                        Do anyone have some information?
                        • digger
                          • Nov 2005
                          • 6192
                          #102
                          What Pistons ? If you mean IE best call them
                          • zaq123
                            • Jul 2016
                            • 1560
                            #103
                            IE/Mahle pistons? all clearances are in the booklet that should've came with the kit:
                            Piston-to-bore Clearance: .002 inches over the coating, measured at 7mm from bottom of skirts; Drag/Endurance racing applications : additional 0.001-0.003"
                            valve to piston minimums: IN- 0.080";EX-0.100"; radially-0.050"
                            piston to head: 0.040"- steel rods; 0.060"-aluminum rods
                            • bradnic
                              • Jul 2012
                              • 3554
                              #104
                              Pics?
                              HOWTOs:
                              DB vert plastic bumpers
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • SkiFree
                                • Jun 2011
                                • 2766
                                #105
                                This.
                                Also, for posterity, I scanned the pamphlet and included other useful information in this google docs file. You should be able to download what you need from here.
                                ADAMS Autosport
