Stock cam markings
  • Kershaw
    • 11822
    Stock cam markings
    I have 2 supposed stock cams. One has zero markings on it, the other has a valvoline looking logo and 4 numbers (something like 1836).
    Anyone have any input on this? Or could check their stock cams for any markings?
    AWD > RWD
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    If someone doesn’t chime in with some info I will check my stock cam thats laying in my garage when i get home in a couple hours.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • zaq123
      • Jul 2016
      • 1556
      I think stock cam is marked by letter...B25 - letter K, B20- L and also they are color coded, pink and blue
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Yes b25 cam has letter K on it. Along with these markings
        • yosh
          • Aug 2009
          • 350
          Pics of one of the ones lying around. Looking at where the sprocket bolts, there are also two line and a "K" 120 degrees apart.
          The other one in my head has an actual bmw stamp in the casting
          And a few other letters.
          Hope this helps.
          • SkiFree
            • Jun 2011
            • 2766
            The "vavoline"-esque logo is typically found on OE cams. If you suspect regrind, what is the base circle measurement?
            ADAMS Autosport
            • Kershaw
              • 11822
              I can take my measurements but I didn't think it was a regrind, but aftermarket. It was a parts car head that made a very noticeable difference in acceleration. I noticed when I took everything apart install a 284.
              But the markings look exactly like the cam Yosh posted.
              Thanks everyone.
              edit: Nevermind, I have no idea how to take measurements with the cam in the head. I thought I could reach around things with a set of calipers. Nope.
              AWD > RWD
              • ForcedFirebird
                • Feb 2007
                • 8300
                Thanks everyone.
                Lift is easy to measure. Put a straight edge across the valve cover gasket surface and measure down to the base circle, then point the lobe up and measure again.
                john@m20guru.com
                Links:
