Differences between Super Eta 885 and 325i 885?
  • AC_Schnitzel
    • Sep 2017
    • 149
    Looking to do this swap pretty soon. I have an 88 325 super eta, and don't know if I should buy a complete 325i head, or just source the cam and dual valve springs.
    From what I understand, the 885 head on the super eta is missing several oil galleys in 2 cam journals. Is this a big deal?
    Looking for somebody who has done this specific swap.
    Let me know what you think!
    JP
    WTB: Z3 1.9 lever, plastic bumpers, 19# injectors, Anthracite Cloth Sport Seats
    Current
    88 325 super eta
    00 528i/5 (daily)
    02 530iA sport
    Former
    04 525iA sport
    87 325is
    91 325i
    97 528i
  • ForcedFirebird
    • Feb 2007
    • 8300
    Camshaft and inner valve springs are all that's different in the head. The 200 casting was not drilled for the 3 extra cam journals (four bearing cam), AFAIK the 885's all use 7 bearings.
    You will also want to change the intake manifold, throttle body and ECU from a 325i to take full advantage of the new parts.
    john@m20guru.com
    Links:
    • digger
      • Nov 2005
      • 6170
      i always thought it needed the holes drilled. i never seen a seta cam to know if it is 4 or 7 journals this might be one http://www.e30tech.com/forum/showpos...6&postcount=16 but not sure
      • ForcedFirebird
        • Feb 2007
        • 8300
        Every seta cam I have held had 7 bearings (half a dozen or more).
        john@m20guru.com
        Links:
        • 2mAn
          SeƱior Mod
          • 20909
          Easy way to figure this out is if he pulls his valvecover off for us and takes a pic, right?
          I thought you had dyno'd a bunch of different combos and the eta intake manifold port patched was the best?
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • M-technik-3
            • 18946
            So what exactly are the differences between a 325e and 325i? Why do some models have an “s”, like a 318is, 325es, and 325is? Is the ’84-’85 318i the same as the ’91 31…
            • ForcedFirebird
              • Feb 2007
              • 8300
              He has the proper pistons by having a seta, so the complete "i" is best for that rotating assembly. If he had flat top pistons (any other eta besides 1988), I would suggest the eta manifold and "i" TB to keep the TQ eta-like while gaining the HP from a swap.
              Either way, the seta manifold (basically eta with the ends opened) is the worst of them all. ;)
              john@m20guru.com
              Links:
              • jeffnhiscars
                • Jun 2011
                • 6011
                Theres always someone causing trouble w actual facts
                Alice the Time Capsule
                • AC_Schnitzel
                  • Sep 2017
                  • 149
                  So I guess what I'm asking is -- is it important to have the extra oil holes? Or can I just drop a 325i cam, and dual valve springs and call it a day? (as far as the head goes... I'm aware I need everything on the intake side as well + ecu).
                  JP
                  Current
                  88 325 super eta
                  00 528i/5 (daily)
                  02 530iA sport
                  Former
                  04 525iA sport
                  87 325is
                  91 325i
                  97 528i
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    I'll say you need the holes and if the head is off its no big deal to bore them. Why risk it for all the work you're doing
                    • 2mAn
                      SeƱior Mod
                      • 20909
                      Has anyone tried to get an eta cam reground?
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        JP, cam should drop in with no additional work.
                        Simon, don't think it's worth it when you could just start with a better stock cam.
                        When the cam is out, the holes are easy to drill, but again, the 885 head has a 7 bearing cam (just eta lobe profile), and we are all talking about it for no reason. :/
                        john@m20guru.com
                        Links:
                        • digger
                          • Nov 2005
                          • 6170
                          the cam bearings are supposed to pressure fed, which matters more when you are turning more rpm and using a more aggressive cam, relying on a pool of oil at the bottom of the bearing is not as reliable which seems like a risk for basically no reward. it doesnt make sense to not drill the holes when its such an easy job
                          conflicting info about SETA cam
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            I have seen a couple of instances on the internet, but have done this very swap many times, and have never seen a 4 bearing 885 in an e30 (not to say that they don't exist).
                            The seta cam has a very similar profile as the eta, I didn't measure much more than lift, though. I once used a seta cam in a 200 head with the dual valve springs in a race car. The rental drivers kept breaking valve-trains with over-revs on a purely eta engine (they needed to stay in a class). So, a seta cam drilled for the extra passages, 325i inner springs, and b25 cam gear setup seemed to do the trick.
                            john@m20guru.com
                            Links:
                            • wilholl
                              • May 2012
                              • 518
                              FWIW, I have a 4 bearing 885 head on my Seta motor currently.
                              1988 325 non-letter Seta "Bronzit"
                              1991 325ic "Laguna Green" (Sold)
                              1993 325i "Laguna Green/Silver" (Sold)
                              1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                              2000 528i Titansilber/gray m-sport
                              2000 528i Titansilber/black m-sport(sold)
                              2001 525i Anthracite m-sport(sold)
                              2013 750i Black/Black m-sport "Beast"
