Extremely loud 19# injectors?
    • 34847
    Originally posted by E30 Reaktionär
    That seems a little low since i got ones that flow 52 lbs/hr in my 2.2 dodge. But i looked up #19 inj. lastnight and it said they flow 19lbs/hr.
    yeah, # is called the pound sign, so 19# = 19lb ;)
    • ForcedFirebird
      • Feb 2007
      • 8300
      I just installed a set of 24# injectors on my Firebird and they are loud compared to stock. (I know this doesn't have to do with my BMW, but same scenerio)
      I am assuming you got the orange top Denso's or Bosch?
      The Ford/Bosch are under rated. The 19# flow more like 21 and the 24's are 25.5.
      john@m20guru.com
      Links:
      • NC325iC
        • Mar 2004
        • 6565
        52# jeezo squeezo, supercharged?
        edit: and yes they are orange topped from ford i think theyre bosch, i want them to shut the hell up
        • ForcedFirebird
          • Feb 2007
          • 8300
          Ain't going to happen. In fact if you meter your o2, I would almost put a penny on it that your running rich. Are you running the stock tune?
          EDIT : The Dodge is probably a 2.2 turbo and 52# are a little thick for that engine, unless there are some hot mods...
          I'm sure I'll be upgrading before too long - I'm going to run out of injector at about 255HP (might be able to squeeze a little mor with the FMU, though).
          john@m20guru.com
          Links:
            • 34847
            they are a little underated. my 19#s flowed about 20.5#. but it also depends on the fuel pressure you are using..
            • ForcedFirebird
              • Feb 2007
              • 8300
              Exactly. Ford uses a lower base fuel pressure, so when a Ford injector is used in other brand cars - they are delivering more fuel.
              john@m20guru.com
              Links:
              • E30 Reaktionär
                Site Manager
                • 14451
                Nope, Turbo built to super 60 specs (allmost), ForcedFirebird, what kind of firebird do you have.
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • NC325iC
                  • Mar 2004
                  • 6565
                  stock fuel pressure (afaik) with a purpose built MarkD chip, though undynoed
                  • NC325iC
                    • Mar 2004
                    • 6565
                    i wouldnt doubt the rich comment though
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      1990 with a 60 degree V6.
                      You had someone tune your chip, or was it a "mail order"?
                      john@m20guru.com
                      Links:
                      • NC325iC
                        • Mar 2004
                        • 6565
                        i told mark my setup and he made me a chip, though he lives in cali so it really hasnt been tested
                        after the ecu resets it runs crazy rich but after a few minutes of driving it levels out more, again i can tell you more once i get the wideband installed, but im very busy/lazy
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          You can pull the Mv off the stock o2 if you have a digital milti-meter, just won't be very accurate compared to a 3-wire or better yet a 5-wire sensor.
                          john@m20guru.com
                          Links:
