Proper way to install manifold studs, M20 head
  • zaq123
    • Jul 2016
    • 1574
    Loctite, anti seize or dry? I've been reading lots of posts and looks like there are no consensus on the question. so what is the proper way? Something tells me dry...don't want for them to get loose. Something tells me zinc anti seize...dissimilar metals
  • rturbo 930
    • Dec 2005
    • 2629
    Well I don't know what's "correct" but I slathered my studs in antiseize.
    • zaq123
      • Jul 2016
      • 1574
      I saw your thread. Did you reduce a torque value for stud nuts? They say wet/dry about 25% difference.
      • rturbo 930
        • Dec 2005
        • 2629
        Nope, torqued em just like the books says. At the time, I didn't even consider that using anti-seize would make a difference vs dry. It's not the kind of part that I'm overly concerned about anyway, if they're tight and they stay on, they're good.
        • zaq123
          • Jul 2016
          • 1574
          the aluminum is why I worry about over torquing it
          • citizen_insane
            • Jan 2013
            • 216
            You're absolutely correct to worry about that
            • digger
              • Nov 2005
              • 6216
              I would anti seize if you want to make it easier to remove later on.
              Since it's a stud and nut and given the anti seize isn't on the nut it doesn't come into play much except when you try and reomove the stud
              • e30davie
                • Apr 2016
                • 1788
                Dont over think it. Clean both bits. No goop. Screw them in, firm but not tight. Done. Worked for me on many engines over the years.
