Engine Rattle At Cold Start
  • varg
    Florida Turbo Man
    • May 2014
    • 3325
    If the valve adjustments don't quiet it down much there could be some piston slap contributing to the cacophony.
    IG @turbovarg
    '91 318is, M20 turbo
    • RoyalW/BlauCheese
      • Dec 2015
      • 126
      Originally posted by gilber33
      I will try a stethoscope and adjusting the valves before running it with the cover off.
      I did confirm the oil pressure light comes on with key in pos 2 with all the other dash lights, but it turns off instantly when I start the car. Doesn't stay on. I'm hoping that's a good sign and I'm just looking at a rocker that needs to be adjusted.
      A stethoscope would be good but you might be able to get away with putting your ear to the end of a screw driver. It just won’t be as accurate. Did you replace the valve stem seals? Maybe that could be the cause?
      _____________________________________________
      1987 325
      • gilber33
        • Jul 2012
        • 244
        I didnt because there wasn't really any evidence they were bad. The intake and exhaust valves were very clean. All my past cars it was obvious the stem seals were bad because the valves would have build up on them from oil seeping past the seal.
        Sent from my SM-G892U using Tapatalk
