Open heart surgery
  • Old525i
    • Oct 2015
    • 32
    Adjust the valves after torquing down the head.
    • Jshbrwr
      • Sep 2015
      • 90
      Is there a reason to do that after installing? [emoji848]
      • zaq123
        • Jul 2016
        • 1560
        when H bolts are fully tightened, some head geometry will change
        • Jshbrwr
          • Sep 2015
          • 90
          Anyone know what these things are? They came in the head set and they aren’t the valve seals or camshaft seal...
          Just got the head back and it looks marvelous
          • redlightpete
            • Mar 2012
            • 266
            Probably for the injectors, cam seal housing, vent tube, and thermostat housing.
            • D.Martijn
              • Sep 2016
              • 1024
              12 small ones are for the injectors,
              2 'medium' ones are for the bitch tube
              Other one is for the intermediate shaft cover I think as the cam seal housing uses a thinner oring
              Big one for the thermostat
              The smallest one, I don't know..
              1990 325iX Touring - November 2018 R3V Car Of The Month
              1980 Volkswagen Golf mk1 1.1
              1974 BMW 2002 Touring
              Instagram
              • Jshbrwr
                • Sep 2015
                • 90
                Thanks guys
                • Jshbrwr
                  • Sep 2015
                  • 90
                  Ok here’s another one -
                  Is it just me, or does one thing not look like the other?
                  The left one fits perfectly but what is up with that other one? I’m thinking that’s not gonna fly...[emoji848]
                  Any insight would be great
                  • zaq123
                    • Jul 2016
                    • 1560
                    That gasket is for 885 "i" head. Yes, return that crap.
                    Just shows you the size difference between two heads, crazy
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      FWIW the first time I opened my first e30 (also an eta) many moons ago, I was surprised the manifold gaskets were from an 885. Unsure if the manifold was ever removed in it's first 70k miles, but I am certain I was the first to remove the head.
                      john@m20guru.com
                      Links:
                      • Jshbrwr
                        • Sep 2015
                        • 90
                        Open heart surgery
                        That’s weird. Makes me wonder what difference it would have made. I let Rockauto know and am waiting on the correct gaskets. Meanwhile, plenty of other things to do before the intake goes back on....[emoji2]
                        Maybe by Christmas...?
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          No difference IMO. The physical castings are the same size, so they seal just fine. I keep 885 gasket sets in stock at my shop and have used the on eta's with no ill effect.
                          john@m20guru.com
                          Links:
                          • bankrupt
                            • Aug 2015
                            • 61
                            What brand gasket set you recommend?
                            • TimeMachinE30
                              • Jun 2014
                              • 3749
                              Was expecting real open heart surgery.
                              ACS S3 Build / Dinan 5 E34
                              • Jshbrwr
                                • Sep 2015
                                • 90
                                Was expecting you really were a time machine
