3.1 liter carnage
  • PA_Welder
    • Feb 2016
    • 82
    3.1 liter carnage
    Had a 3.1 liter stroker using the kit from I.E. spin a rod. A decent amount of bearing material went through the engine and oil pump just wanted to get opinions whether the oil pump is still good it was new when it was put on and anyone's opinion on if the pistons could be reused.
  • zaq123
    • Jul 2016
    • 1559
    you can probably polish pump's lower surface if those scratches aren deep. Hard to tell from your pics about pump's gears. Pistons's could be ok too if scratches aren't deep, just clean up raised ridges. Check your crankshaft very well..it's most likely probably damaged too. Don't forget to pull both oil gallery plugs in the block and clean it well.
    What happened? How many miles on the build?
    • zaq123
      • Jul 2016
      • 1559
      other look at your pistons... those re just very minor surface scratches? right? No shape deformations?
      • SkiFree
        • Jun 2011
        • 2766
        The oil pump is done, at least the lower casting portion.
        ADAMS Autosport
        • digger
          • Nov 2005
          • 6180
          If that's only issue with pump I'd try and lap it out
          • TobyB
            • 5286
            ...but a couple of those pistons look like they stuck to the cylinder walls-
            as always, try measuring first, then maybe see if they'd clean up with a polish
            and re- texture...
            t
            • hasa
              • May 2013
              • 307
              I'd continue with the current parts after slight polishing.
