Weird m20 head damage. Repair or replace?
  • pandaboo911
    • 2070
    Hey guys, looking to see if anyone has seen damage like this to an m20 head.
    It’s strange localized corrosion. The head was resurfaced and head gasket was replaced 1 year ago. It failed a couple weeks ago and these pieces are missing from the head.
    Is it worth welding these up or just get another head?
    Cheers
  • Zambuzan
    • Nov 2017
    • 434
    what happened?
    "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
    • justinpirie
      • Feb 2014
      • 111
      Originally posted by Zambuzan
      what happened?
      No anti freeze?
      • Joegreen02
        • Dec 2018
        • 80
        Looks like you might have been running too much water in the coolant causing some boiling and cavitation. Get a machine shop to fix it up. Looks repairable
        • zaq123
          • Jul 2016
          • 1483
          look more like a galvanic corrosion to me, pretty bad one too. I wouldn't reuse that head. M20 heads can be found cheap
          • Joegreen02
            • Dec 2018
            • 80
            Yeah you might be right there. It's probably repairable though. I wouldn't repair it myself but...
            • digger
              • Nov 2005
              • 6080
              the sealing surface is fixable but the issue is what about the corrosion you cant see......
              • Andre3127
                • Dec 2017
                • 291
                I'd try and fix it if you know a guy who can do the work for cheap, but it's a gamble because there are other coolant passages that could also be corroded.
                Budget E30 Parts - Used and Reconditioned parts for your BMW
                • Joegreen02
                  • Dec 2018
                  • 80
                  Valid point
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5224
                    The corrosion should be the most advanced at some crevice (Where it meets the head gasket, heater core fitting, thermostat). Probably isn't quite as bad on the inside
                    Originally posted by priapism
                    Originally posted by shameson
                    • ADEN
                      • 620
                      Looks very repairable machine shop fill these missing gaps
                      • nrubenstein
                        • 3148
                        Did you grab a bottle of acid instead of distilled water? :p
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • pandaboo911
                          • 2070
                          Prior to this happening I replaced the headgasket, filled it with anti-freeze and water. Then it started to lose coolant quickly, and pressurize the cooling system, overheating at idle.
                          I imagine it's corrosion but its so localized, I can't see that happening in one year. The rest of the coolant passages look ok. Why would it corrode on just 3 / 6 cylinders?
                          Is it possible that hot combustion gas was leaking past the headgasket and the cavitation or pressure was eroding the aluminum away?
                          • zaq123
                            • Jul 2016
                            • 1483
                            last picture has some signs of some combustion leakage, the others look like HG was still holding. This is most likely to the extremely poor coolant maintenance over the years. Coolant looses its properties faster than some think.
                            Like I said before, I would not reuse this head. There is a high change that there is more corrosion inside the head and one can't tell if there aren't any paper thin spots.
                            Save your money and time, invest in another head.
                            • e30davie
                              • Apr 2016
                              • 1788
                              I will agree with this and put a vote in for repair and re-use. but I would get the opinion of a cylinder head re conditioner before doing anything. Everyone has "their guy" and the guy i use has done some decent repairs for me over the years and has also given me the "mate she's stuffed, bin it" as well.
