Crank bolt removal? Impact doesn’t work
  • ErickEnriquez
    • Jan 2018
    • 121
    I’m having loads of trouble removing my crank bolt. I’ve used 2 impacts and then bought a harbor freight impact that’s supposed to be good for 1200 ft lbs and the bolt still won’t come off. I even got it to where I wasn’t using any extensions but no luck. If anyone could give me any advise that would be great. Or if someone has the crank holder tool in the Houston area that would be even better.
  • noid
    • 1537
    What air compressor and PSI are you running?
    3/8 lines and fittings?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • e30davie
      • Apr 2016
      • 1788
      I got a second crank pulley and welded a piece of 2" angle to it. Then got a massive breaker bar onto. And put a 4foot length of pipe on the breaker bar.
      • ErickEnriquez
        • Jan 2018
        • 121
        Running a pretty large compressor don’t know the size. And 90 psi with 3/8 hose like the impact recommends
        • noid
          • 1537
          Most air tools 'recommend' 90 psi, but really most shops run 120 psi. Working air pressure vs static air pressure means that if you set your compressor to 90 psi static pressure, when you use the impact, working pressure will be around 60-70psi.
          Hopefully you have 3/8 NPT fittings on your hose; if not, remove any quick connects and run the line straight into the impact.
          Advertised breakaway torque means very little, you want to be looking at the max working torque.
          • jeffnhiscars
            • Jun 2011
            • 6011
            Use the crank holding tool and a breaker bar with extension (I use my floor jack handle). You'll want this anyway unless you plan to use the impact to replace it
            Alice the Time Capsule
            • LowR3V'in
              • 4209
              hey just fyi don't run a regulator at all.
              the 90psi at the tank is like 70psi when u pull the trigger and 50psi at the gun after the hose and the fitting.
              There are high flow milton fittings that work and you should use them for
              high flow work like this.
              i'm just saying because also had this problem with an aircat i thought it was
              a pile of shit but turned out to be my setup.
              That shit spun the nut off so fast after that it was the setup.
              also 50-60ft hose length kills allot of power for real a 25ft will help a ton but do that last if u need to.
              better yet don't even run a coupler on the tank just run the hose straight tank.
              for now just since ur in a pinch just run the hose to the gun with no couplers or regulator,
              put alittle squirts of gun oil in to seal the vanes and it should rip.
              • zaq123
                • Jul 2016
                • 1570
                Are you rebuilding the engine ? If not ...big ass bar with a big ass pipe and big ass friend is you best bet. I would highly recommend not to use the impact gun on the crank. Crank thrust bearing won’t like all that beating.... if completely rebuilding....different story
                As far as the holding tool...go to HD and get 4-5’ long iron stock, half moon notch it for the bolt spacer and drill 3 holes to bolt to the crank gear.... under $10
                • Andre3127
                  • Dec 2017
                  • 291
                  I made a tool to span over the crank pulley bolts. Some are super easy to remove, some take around 300 foot pounds (if I had to guess a number).
                  Budget E30 Parts - Used and Reconditioned parts for your BMW
                  • Reichart12
                    • Aug 2012
                    • 2166
                    Silly question but is the engine still in the car and is the transmission in gear?
                    Instagram: Reichart12
                    • nrubenstein
                      • 3148
                      Borrow either the big Dewalt or Milwaukee battery powered impacts. I bet your HF gun at low pressure isn’t giving you much.
                      2002 BMW M3 Alpinweiß/Black
                      1999 323i GTS2 Alpinweiß
                      1995 M3 Dakargelb/Black
                      - S50B32/S6S420G/3.91
                      1990 325is Brilliantrot/Tan
                      1989 M3 Alpinweiß/Black
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5611
                        If the crank is moving at all while you're using an impact, it will not work.
                        A few tips... really want to be at 120psi
                        wait until the compressor shuts off at max pressure before using it.
                        put a little oil down the fitting on the impact gun
                        and make sure that crank doesn't move a MM while trying to loosen it..
                        • ErickEnriquez
                          • Jan 2018
                          • 121
                          Sorry just looked back at the thread. Someone on revlimited messaged me and had the tool locally and I got it off with that and a pipe. Thanks everyone.
                          • r-mm
                            • Jun 2018
                            • 203
                            For what its worth I have never encountered a fastener that my harbor freight 1/2 inch drive electric impact has not been able to remove. The truth is my Bosch 18 V handles 90% of what I encounter and I do a lot of old car/truck work but when things get really ugly the harbor freight 120 V has never let me down. That and MAPP
                            • hotsaucewizard
                              • Sep 2013
                              • 93
                              mine was surprisingly easy...
                              i just locked the crank in place using a wrench on the little alignment cylinder for the flywheel and jammed that against the motor stand
                              18 inch breaker bar on the crank bolt with the top of my jack handle on the end of it for about 3 feet of bar... popped right off
