M20 Header Options in 2019
  • digger
    • Nov 2005
    • 6172
    #31
    Originally posted by zaq123
    do you mean RD headers?
    no, i was referring to AAF but purely from a quality perspective, size wise they are waaaaaaay off.
    RD are a shadow of their former self IMO
    • zaq123
      • Jul 2016
      • 1559
      #32
      I have ordered RD (long process so far) just for the sake of o2 sensor placement and some additional road clearance. Have a set of brand new BavarianAuto long tube headers but not sure if that's what I want....They seem to be superior to RD design as far as performance goes but their low clearance will probably be an issue for me. I also want to place o2 in between both banks and on the vertical run (similar to oem design). Long Bavauto headers are pushing 02 way back and lay it flat..something I'm trying to avoid
      • digger
        • Nov 2005
        • 6172
        #33
        Running the same dbilas cam ?
        Got any measurements for those headers ?
        • zaq123
          • Jul 2016
          • 1559
          #34
          switched to schrick 288 for ITBs.
          headers specs: 1 3/8” primaries, 2” collector into 2” mid-section
          • digger
            • Nov 2005
            • 6172
            #35
            The question is do you want to boost:
            A) bottom end/midrange or
            B) midrange topend
            The RD should suit the itb characteristics better as the shorter length primary is intune at a similar rpm to the inlet manifold. the bavauto should be better in tune with stock intake due to both having longer lengths that tune in at the bottom end mid range.
            • zaq123
              • Jul 2016
              • 1559
              #36
              B) midrange topend
              Since this e30 is more of a toy, option B is my goal.
              • digger
                • Nov 2005
                • 6172
                #37
                Then the RD is likely going to be more suitable. Ofcourse you still need to have the rest if the system done sensibly
                • zaq123
                  • Jul 2016
                  • 1559
                  #38
                  now I just need to receive those RD headers...
