1.3 Motronic Up-Grade & 2.7i How To
This is a sticky topic.
  • deeze30
    • May 2013
    • 298
    #391
    awesome thread
    informative, been reading and makes me want to work on my eta right now haha
    I'm in the process of getting a complete 89 325iC from someone for my 84 325eta. I know it was mentioned here that everything is pretty much swap i parts to e with NO machining or custom pistons (unless you want to) needed right? I also saw that bolting a stock i head to eta block will be a low CR, which is fine because i plan to turbo the car later down the road BUT it will cause the car to have rough idle and hard start.
    Would buying a chip fix this issue? I'm trying to avoid any machining work because I don't have access to one and I know they can be pricey but IF i do, what part specifically and what machining needs to be done? and if so, how much you reckon it would cost? Thanks
    • Andy.B
      • Sep 2011
      • 1650
      #392
      I have a 'low compression' 2.7i (stock 2.7 bottom end with 885 head) with a BimmerHeads regrind cam and sssquid 2.7i 93 octane chip.
      The car starts and idles fine in all but the coldest weather ( < 0° Fahrenheit).
      I suspect the stories of it running rough or being hard to start are due to intake leaks, not the slightly lowered compression.
      • deeze30
        • May 2013
        • 298
        #393
        Is the regrind necessary? How much did that cost? How you like sssquid? Better than markd? Cheaper too
        • Andy.B
          • Sep 2011
          • 1650
          #394
          The cam is not necessary, but man is it fun!
          I bought a rebuilt 885 head with cam, adjustable timing gear, and chip, all at once from BimmerHeads. I don't recall the price, but it was a great deal all things considered.
          I can't speak for the mark d tune, as one never experienced it, but I will say am happy with the sssquid tune.
          • deeze30
            • May 2013
            • 298
            #395
            Thanks for clearing up my concerns :up:
            Now i just need to pick up this 325i parts car and get to workin :) maybe i'll consider rebuilding the head and anything else before i do the swap.
            • squidmaster
              • Aug 2011
              • 2666
              #396
              I love my 280/274 dual regrind from BimmerHeads!
              :up:
              • modernist
                • Apr 2014
                • 283
                #397
                Yeah yeah, excited to be starting my swap soon! 12/85 eta bottom end, 2.5i everything else
                - M50 17lb injectors: y/n
                - DME: is the stock 325i chip useable, or is a 2.7i chip imperative? Motronic 1.3
                - block deck: cleaning advice?
                1986 327i
                transaction feedback
                DIY thing
                meh
                • squidmaster
                  • Aug 2011
                  • 2666
                  #398
                  stock is usable, but a correct tune will help with every aspect of your build, from idle to mpg.
                  • Regnar75
                    • Sep 2011
                    • 483
                    #399
                    definitely go with a custom chip to fit your tune. tell them what injectors you have, pistons (flat top) what AFM your using etc. ^squidmaster has some great tunes and prices, and also extremely helpful
                    • deeze30
                      • May 2013
                      • 298
                      #400
                      Thinkin about the injectors also. Planning on FI later down the road if funds permit so probably a good idea to up the lbs already but then again i'm probably going to be limited to 10psi max if i did. (Maybe haha)
                      Definitely clean and rebuild 885 head before slappin it on might be a good idea. Idk how hard it would be to semi clean the block without pullin it out the shell.
                      • Rickyloc187@yahoo.com
                        • Aug 2014
                        • 15
                        #401
                        sorry its off topic but can anyone tell me what these wires are for or what they connect to on the link below,
                        • Funkyasshit
                          • Mar 2015
                          • 7
                          #402
                          So what should I really need If I have 1985 e28 with ETA engine? All the same parts that are listed in needed and optional in the first page?
                          • deeze30
                            • May 2013
                            • 298
                            #403
                            Thinking of using 17lb or 19lb injectors for the 2.7i conversion. Or stick with a rebuilt i stock injectors? What do you guys think?
                            • squidmaster
                              • Aug 2011
                              • 2666
                              #404
                              The 17lb and 19lb both offer better spray patterns and fuel dispersal. The plastic body 19lb injectors are usually the go-to for upgrades, since they are generally newer, easier to rebuild, and tend to work a little better. Though I will say I've never bought a bad M50 injector, whereas I have gotten a couple duds from the Ford 19lbs.
                              • deeze30
                                • May 2013
                                • 298
                                #405
                                I see. I'm planning on FI later down the road and going 19s now would probably be a good idea and maybe move up few later. What part number am i looking for? It's just there's a bunch of them out there with same yellow top but part # will ID it.
                                On a side note, i know running 19lbers will cause tune issues with stock DME, do you support a chip for this application? So far injectors are the only ones i'm planning on replacing over stock with the 2.7i conversion.
