what can we do to give Mr m20 power
  • Sean
    • 5793
    Originally posted by Fidhle007
    MarkD Chip, Bav Auto CAI, GOOD heatshield of some sort, Exhaust.
    All of you who think you're going to get a full rebuild for $1500 are dreaming, plan at LEAST twice that to build a good M20 with new parts. And at that price you might as well add some extra valves and variable cam timing. Boost is another story though, I would happily spend money on an M20 built for boost but for some reason I balk at spending it for an N/A motor.
    You could do a rebuild using eta bottom end, super eta pistons and stock I top end for $1500. I spent about $600 on all rebuild pieces and probably $300 for machine work. That's just for the bottom though. My top end is still original, close to 210,000 on it now. If you get new pistons and a different crank - most def. not.
    - Sean Hayes
    • eugeman
      • Sep 2007
      • 306
      Everyone says go turbo and it's not that I disagree in terms of raw HP, but if you have to consider tuning, emissions, driveability, fabrication, parts breakage in the turbo system and stock parts, and mpg in the equation as well. I'm going N/A modified stroker.
      • James Crivellone
        Head Janitor
        • 6304
        Originally posted by nefarious7907
        I honestly dont think the M20 is worth rebuilding, you would be better off swapping to an M5x motor
        My 2.8L M20 can destroy a stock M20B25, its fun as fuck...
        Ask anybody who has seen mine (or nando's for that matter)
        • nefarious7907
          • Jan 2005
          • 1170
          You mean M50B25?
          http://www.cardomain.com/ride/657387
          • Sean
            • 5793
            You mean M50B25?
            It would kill an M20B25 too though. :D
            But yea, James ain't lieing. I walked away from my brother's 325is, and that's before I've even messed with any tuning (173 ECU with STOCK I chip and stock AFM - only upgraded injectors). When I get MegaSquirt dialed in, I should easily gain 5 hp, maybe more.
            - Sean Hayes
              • 34839
              sean - I highly reccomend you get a baseline on your engine before you switch to MS. preferrably on a mustang or dyno dynamics (a real load brake dyno). not for the ultimate HP numbers (which aren't all that important), but so you'll know what you really gained between them. Then, when you go back with MS you can fine-tune the timing and AFR curves on a load brake dyno.
              I got a baseline but I made the mistake of doing it on a dynojet - it was still helpful, but since it's not a load brake dyno all I can really tune is WOT, although the guys at the place I went to were pretty clueless on how to tune it anyway. of course I still gained 10-15hp/tq (at the wheels) over my baseline, with the biggest increases in the top end from 6000-6500. :)
              • Sean
                • 5793
                Actually, instead of going to the dyno more than once, I got a Gtech pro Meter, pretty much the equiv of the Gtech pro RR for around $100 on ebay. I'm going to find a nice stretch of road, fill up my car with gas (like completely full) and do a run. Then after I get MS dialed in, I'll do the exact same thing - and hopefully it will give me a comparison. :)
                Is the only way to really tune the midrange, and not WOT, on a dyno, that is, for the ignition anyway?
                - Sean Hayes
                  • 34839
                  yeah, you can't really do anything but WOT on the street. you can do some VE table tuning but it takes a lot of time and patience.
                  too bad you paid $100 for the g-tech, a baseline may have been cheaper :p
                  • Sean
                    • 5793
                    Doh..ya. Possibly, but I'm gonna play with it for a bit. I really don't know what the dynos are like in Boise. I can resell it for the same price too. lol
                    - Sean Hayes
                    • digger
                      • Nov 2005
                      • 6119
                      i have heard of people using the brake as a load at WOT to maintain constant rpm for short intermittent periods. Do it on a big hill and it will take some load of the brakes.
                      • digger
                        • Nov 2005
                        • 6119
                        what does your stroker put out nowadays? Also what are the specs
                        • z31maniac
                          • 17566
                          They use the 3.2 M3 crank, but stock it will not drop right in because the ends are different.
                          Hmm, their site says you have to notch the block for rod clearance, not because the ends are different.
                          Not saying you are wrong, just curious which is right. Or if you have to do both.
                          www.gutenparts.com
                            • 34839
                            you may have to clearance the block and intermediate shaft - the only modification to the crank is a pressed on sleave for the front seal.
                            • kamotors
                              • Nov 2007
                              • 7102
                              Originally posted by E30Idea
                              Drive down hill only with your foot on the gas
                              sadly that doesn't help. i did some 0-60 runs down hill and they were only .3 seconds faster. 4.10's hold you back to much going downhill.
                              but for more power go get a turbo
                              7speedshop.com
                              • Jon325i
                                • 6934
                                Lots of good suggestions being tossed around in here - but lets ask one very vital question of the original poster. And that question is.....
                                What's your budget?
                                Jon
                                Rides...
                                1991 325i - sold :(
                                2004 2WD Frontier King Cab
                                RIP #17 Jules Bianchi
